Pledge - Road Glide Forums
General Off-Topic Discussions Non-Road Glide Topics
post #1 of 20 (permalink) Old 10-05-2009, 07:08 PM
Redfish Joe
Guest
Posts: n/a
Pledge
I gotta ask. How many of you use Pledge on your bikes? If you haven't give it a shot. Light spray and wipe off with a microfiber cloth and you have a great shine and you can use it on your windshield. Helps to keep bugs from sticking.
post #2 of 20 (permalink) Old 10-05-2009, 08:35 PM
Admin
BillyBob's Avatar
Don't know about that. Doesn't it have chemicals for wood in it?
BillyBob is offline
post #3 of 20 (permalink) Old 10-05-2009, 09:56 PM
The Infamous Sharknose
Guest
Posts: n/a
I have heard hundreds of testimonys but man...I just couldn't get up enough nerve to try it eventhough nobody has ever said anything adverse from using it.
I went with a metric friend to a local yamaha shop so he could order some parts and while I was waiting I saw this stuff called Honda Detail Spray. It is basically a non abrasive cleaner with polish and wax. Man...this stuff works great and leaves a nice slick surface. It takes the bugs right off and helps protect and give a deep shine.
I know....you guys are scared to put honda products on your harley
post #4 of 20 (permalink) Old 10-05-2009, 11:32 PM
Bandit's Avatar
I use it. It IS NOT my main wax by any means, but it does help for a quick wipe down and to keep the bugs from sticking. I've been using Pledge for close to 20 years. First learned of it, and started using it when I worked for a local snowmobile shop back in 88'. I thought the owner of the shop was nuts until he showed me how it worked.
I repeat.... DO NOT use this for your only form of wax.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #5 of 20 (permalink) Old 10-06-2009, 01:21 AM
Redfish Joe
Guest
Posts: n/a
There ya go.
post #6 of 20 (permalink) Old 10-06-2009, 01:32 AM
Redfish Joe
Guest
Posts: n/a
I ran across this on another site
Lets start out with the actual ingredients found in a spray can of Pledge.
Please note that the base formula will be different being dispensed from a spray can or pressurized aerosol vessel due to the fact that a "propellant" is needed to transfer the product from the container to a surface, in this case lets say a fender or a windshield. A trigger plastic spray container would not require this propellant additive.
For the purpose of this discussion, I will list the information relative to Pledge in the aerosol spray can as it appears to be the most common used by others on this forum.
The base ingredients are:
1. Naphtha, petroleum, light alkylate 5%-10% or (isoparaffinic hydrocarbon solvent)
2. Polydimethylsiloxanes (Silicon oil) 5%-10%
3. Water 70%-85%
4. Butane1% -5%
5. Isobutane1% - 5%
6. Propane1% - 5%
Now we can breakdown what these are and what they do.
The first ingredient is:
1-Naphta,petroleum,light alkylate.
This is a hydrocarbon solvent-based dispersant formulation which combines oil penetrability. In other words remember the label says "smear and smudge proof"? These are the ingredients that will break down and remove the smears, finger or dermal tissue oils. Criminals take note.. use this to eliminate finger prints. Just dont be a dumb (EDITED) and leave the can behind!!
Now, what is a hydrocarbon?
A general term for organic compounds which contain only carbon and hydrogen. They are divided into saturated and unsaturated hydrocarbons, aliphatic (alkane or fatty) and aromatic (benzene) hydrocarbons. Crude
oil is essentially a complex mixture of hydrocarbons.
To break it down even further, I will now define an organic compound.
An organic compound is any member of a large class of chemical
compounds whose molecules contain carbon.
What is carbon you asked? I knew ya would!!
Carbon is a chemical element with symbol C and atomic number 6. As a member of group 14 on the periodic table, it is nonmetallic and tetravalent (a state of an atom with four electrons making four electrons available to form covalent chemical bonds.)
A chemical element is a type of atom that is distinguished by its atomic number; that is, by the number of protons in its nucleus. The term is also used to refer to a pure chemical substance composed.
What does this all mean?? It is a pure chemical substance.
Why is it in there? Remember the finger print? It is a solvent that removes oily residues. This is the cleaning agent in the product.
Look at the can.."It dusts and cleans". this is what makes it clean/remove dirt,grease,oil,grime.
That was the more lenghty one. The remainder are relatively simple. If you are still reading at this point, thanks for bearing with me.Go grab another beer! I will summarize at the end and compare to other products on the market in terms of ingredients, costs and results.
The second noted ingredient is:
2-Polydimethylsiloxanes or Silicon oil 5%-10%.
This is silicone based oil. The molecular structure of this is such that friction is significantly reduced. This nifty additional ingredient is also the reason why the ..refer to label again.. NO WAX BUILD-UP!! Silicone will blend with it'self and not mix or layer with other chemicals.
It does however have the ability to piss bike painters off due to the fact that it needs to be completely removed proir to coating with paint. If not...start all over again. It makes surfaces slick so that nothing sticks. It also provides the shine to the surface.
This chemical is also present in 95% of products us bikers use on our scoots such as Armor All, Meguires Wax and STP Son of a Gun just to mentiion a few so if you are worried about using Pledge in the past on your bike, you may alraedy have and just did not know it.
This silicone oil is also an ingredient in Right Guard deodorant, baby powder,Desitin, Gillette Dry and several moisturizers and creams. This is why Pledge does not contain wax, they use this instead.
Makes me want to try it with the goa....wife!
To the guy that posted about the fella steping on his fender and sliding off...about to 5 drops of this in a drink will cause lets just say possible incontenence" which will then require the need for additional Desitin with the same ingredient to help that diaper rash from the copiuos ammounts of passing solids!!! Great stuff ain it?
The third ingredient:
3-Water. This acts as a dilutor. Kind of like "filler" in cheap dog food but in liquid form.
Cant use the product undiluted.
The remaining butane, isobutane and propane are the propellants that assist in expelling or propelling the liquid product from the can. The methane is building under pressure and the propane, butane provides the ignition source. Kinda like putting your tounge on a 9v battery. You know you are gonna do it eventually when no one is looking. Try chewing aluminum foil!! Nah...dont do that either.
Other ingredients such as aromatic compound like orange, lemon or any other organic scent additive can also be incorporated.
Now with this little snippet of knowledge, how does one apply it to everyday living.
If Martha Stewart says that a prison panty liner work just as well as a microfibre cloth stop reading. If not..please bear with me for I am almost done.
Several products out there are costly for several reasons. 1 because of proprietary ingredients/raw materials, 2 advertising costs, supply and demand and product to market costs. What will the market bear? I have always compared ingredient when shopping. Silicone oil is silicone oil, Pepto Bismal, for the guy trying to stand on the fender coated with silicone oil is pink Bismuth...same thing!
Pink bismuth is MUCH cheaper.
I heard of a product called Plexus. A great cleaner and conditioner for Lexan. At $15.95 for a 13oz can versus an 18oz $4.99? can of Pledge? I have not bought or used Pledge and do not know the actual cost I am sure it is not even close to this other product.
In summary:
* Will not damage finish
* Will provide a nice shine
* Will not build up or layer
* Safe on windshield. No alcohol or amonia
* Safe on chrome
* Also has some (although not real good) anti corrosion properties. I use Boeshield T-9 for this application.
One precaution!! Flammable! Do not use around open flames or on hot pipes or other hot components. Do not get on or use on denim ar matted finishes!!
I would also highly recommend that a wet or water wash, or a soft wetted cloth, (I use warm clothes because the heat helps soften bug guts better than cold) be done or used first to remove surface debris and particulate from the soon to be applied to surface, fenders, gas tanks,side panels. This will reduce potential scratching of your paint.
Well, I hoped this helps. Like I said, I have never used "Pledge". But I have applied the same ingredients in Pledge (just under a different name...Maguires Wax) on my bikes not knowing it, and they have all looked great!
post #7 of 20 (permalink) Old 10-06-2009, 06:46 AM
Gummiente's Avatar
I used the Honda spray for a few years, it was easy to get because the local Harley dealer also sold Honda. One day I went to buy some and they were out of stock, but they had the Harley spray cleaner/polish so I tried that. I found that it works just as well as the Honda stuff and have been using it ever since. I moved to a new region last year and the Harley and Honda dealerships here are separate, so I just use the HD spray now. Never tried Pledge on their bikes but I have known people who swear by it. I recently started using it on all my leather gear and it does a great job of cleaning and waterproofing all of it. For the windshield, I have been using Plexus for years - best stuff on the market, IMO.
Gummiente is offline
post #8 of 20 (permalink) Old 10-06-2009, 09:36 AM
rippedglide
Guest
Posts: n/a
We rode from Raleigh, NC to Laconia, NH this past June. I didn't wash my bike the entire trip. When I got home and washed the bike it was amazing how easy everything had cleaned up. Pledge works great and it did absolutely nothing to my paint. I will def. use it again when I go on a trip. BTW, that is the only time I put it on the bike.
post #9 of 20 (permalink) Old 10-08-2009, 12:19 PM
Admin
BillyBob's Avatar
Jeeze ---- Redfish,
just reading your chemical descriptions give me cancer
BillyBob is offline
post #10 of 20 (permalink) Old 10-08-2009, 05:10 PM
Littlebear
Guest
Posts: n/a
I have used pledge for years will no ill effect, Honda and Harley spray also. All of it is used over several coats of nano wax tho.
Pledge varider General Off-Topic Discussions 15 12-28-2017 06:34 PM
Wheels to the Wall Pledge Ride JohnnyIce Videos 0 04-24-2016 07:12 PM
Wheels to the Wall Pledge Ride JohnnyIce Organize Rides Here 0 03-14-2016 10:05 AM
I pledge allegiance to the flag.... Quicksand ARCHIVES-SWI Gettysburg, PA 8 10-17-2011 09:41 PM
