Fuel additive? - Road Glide Forums
General Off-Topic Discussions Non-Road Glide Topics
 14Likes
post #1 of 18 (permalink) Old 01-01-2018, 04:38 PM Thread Starter
Jacksprat56's Avatar
Fuel additive?
Need some expert advice from the best "crew" on the net! I haven't left a motorcycle parked as long as this in so long I can't remember when it would have been. My bike sits in a garage heated to 55 degrees due to water softener, pump, etc. I have a gas station 2.2 miles from the house and I always fill the tank up there after a cold weather ride b4 parking it. Looks like it's gonna be a long cold spell and I'm not sure if I need to "stabilize" my fuel or not. If so, what should I use? Thanks in advance for the advice.
Let us hear the conclusion of the whole matter: Fear God, and keep his commandments: for this is the whole duty of man. (Ecclesiastes 12:13)
Jacksprat56 is offline
post #2 of 18 (permalink) Old 01-01-2018, 04:43 PM
Road dawg's Avatar
Star Tron has a enzyme treament for the fuel which I love and also doubles as a fuel stabilizer and it's available everywhere, good stuff.
Road dawg is offline
post #3 of 18 (permalink) Old 01-01-2018, 05:06 PM Thread Starter
Thanks Road dawg; almost sounds like you run this all the time; is that correct? As crappy as gasoline is these days I've wondered if it would be a good idea. I run Sea Foam through my other vehicles twice a year; never had an injector problem. Wadda ya think? I've never seen Star Tron but getting ready to Google it. Thanks again.
post #4 of 18 (permalink) Old 01-01-2018, 05:17 PM
+1 on the Star Tron. I use it several times during the riding season and the last top off before winter. I pick mine up at Autozone.
Jacksprat56 likes this.
2012 FLTRX, vivid black
sometimer is offline
post #5 of 18 (permalink) Old 01-01-2018, 05:58 PM
eddienelson's Avatar
Actually fuel quality has greatly improved in the last 3 or 4 years. Its keeping its octane rating longer and not breaking down as easy as before ie gumming carbs etc. You can thank the marine industry for that. The refineries had to somewhat change the formula or something like that. Im pretty messed up and not sure if this making sense.
Jacksprat56 and Little Wing like this.
2016 RG Custom Vivid Black
eddienelson is offline
post #6 of 18 (permalink) Old 01-01-2018, 06:41 PM
Road dawg's Avatar
It's also great from protecting your fuel system from the damages of ethanol which hey add to fuel, I use it quite frequently, really good stuff , and as mentioned here available at AutoZone.
post #7 of 18 (permalink) Old 01-01-2018, 07:20 PM
madmat's Avatar
+2 Star Tron. Use it in my bike, tractors and snowblower with good results.
18 RGS Bonneville Salt Pearl
madmat is offline
post #8 of 18 (permalink) Old 01-02-2018, 03:08 PM
wevsspot's Avatar
I'm old school. Still using STA-BIL. Have always used it in my marine applications with good success, and since I keep a big bottle of it around anyways I use the same treatment in all of my 2 and 4 cycle gas motors.
May have to try the Star Tron now though................. Autozone is just right around the corner from the O'Reillys that I normally shop at.
wevsspot is offline
post #9 of 18 (permalink) Old 01-02-2018, 04:01 PM
ERod62's Avatar
Running star Troy now but for years also used Lucas ethanol gas threadment changed due to availability. The Star Tron can be purchase anywhere on my area.
I used frequently.
ERod62 is offline
post #10 of 18 (permalink) Old 01-02-2018, 04:23 PM
Little Wing's Avatar
interesting.
i tore apart a carb on a bike that was sitting for a year because the float bowl was seized by some sort of algae or mold.
was using HD fuel treatment but switched to sea foam. i like it because if you add too much it doesn't dilute the fuel like a lot of them do.
the fact that StarTron uses an "enzyme" to attack the algae or mold is kinda clever, though.
Little Wing is offline
Octane Additive? KansasFLTRU General Off-Topic Discussions 5 02-12-2018 07:29 AM
Additive for reducing carbon buildup Sideways Fluids and Lubricants 21 07-04-2014 02:28 PM
Gas additive for winter vlgolf *General Road Glide Discussions/Pictures 31 11-02-2013 01:08 PM
Who uses Sea Foam or Star Tron additive? joke *General Road Glide Discussions/Pictures 30 11-25-2012 02:42 PM
Magnetti-Morelli Fuel Injection with V&H Fuel Pack emorris ECM/Fuel Management systems 5 10-08-2012 10:17 AM
