security fob help - Road Glide Forums
General Off-Topic Discussions Non-Road Glide Topics
 10Likes
post #1 of 18 (permalink) Old 09-07-2019, 03:09 PM Thread Starter
security fob help
2012 Ultra, lost my key. The spare key battery was dead, so I changed that. Bike would not start. Entered the Harley code: 31313. No dice. Of course can't find my code or remember it. Dealer said they would have to come and pick up bike next week. I will spend the time RE-looking for the key. Any suggestions guys. I can't be the first a hole. The brain is a terrible thing to wast.
P.S. Found the code since first post. But it is only 4 numbers and bike calls for 5!!
2012 Road Glide Ultra
antant is offline
post #2 of 18 (permalink) Old 09-07-2019, 04:01 PM
woverby's Avatar
Send a message via Skype™ to woverby
Did you ask the dealer if they set the code on the bikes they sell? Some dealers change the factory default to their own. My son's default code was all "1s".
madmat likes this.
2017 FLTRU
Colorado Springs, Colorado
woverby is online now
post #3 of 18 (permalink) Old 09-07-2019, 05:00 PM
skratch's Avatar
then you didn't find the code.
did you double check that the battery is installed correctly in your spare fob? this is a very common error made when changing the button batteries. even if your bike won't start, if it is recognizing the fob, you should be able to pull up your existing pin code.
try the last 5 of the vin, that's what my dealer uses when they set the default.
after this gets taken care of, set the code to something that you can remember (last 5 of ssn, etc) so that you don't go through this again. and, it wouldn't hurt to actually practice the procedure. better to go through it in your own garage than out on the road somewhere.
RonC26 likes this.
skratch is online now
post #4 of 18 (permalink) Old 09-07-2019, 06:28 PM
woverby's Avatar
If perhaps the four digits are a correct part of the code, try the four digit number then 1,2,3,4,5,6,7,8,9 (nine tries) and also 1,2,3,4,5,6,7,8,9 + the four digit code (another 9 tries). Worth a try in desperate times!
2017 FLTRU
post #5 of 18 (permalink) Old 09-08-2019, 07:50 AM Thread Starter
The battery is in correct, checked twice. Tried the vin. Talked to dealer and tried the numbers he sets them too but I must have but my own numbers in and did not write them down. Yea I know and your right. I will keep trying, thanks.
antant is offline
post #6 of 18 (permalink) Old 09-08-2019, 08:07 AM
RonC26's Avatar
2 stray & most likely bad ideas .......
- parked near some funky radio interferences?
- sure you got right fob (not from another previous bike)?
ďA ship in harbor is safe, but thatís not what ships are built forĒ - John A Shedd
RonC26 is offline
post #7 of 18 (permalink) Old 09-09-2019, 02:39 AM
texasnurse's Avatar
security fob help
Delete
texasnurse is offline
post #8 of 18 (permalink) Old 09-09-2019, 06:33 AM
Are you sure it's a security system problem? When you say it "wont start" is it turning over and wont start or are the lights coming on and it doesn't make a sound when you it the start button?
post #9 of 18 (permalink) Old 09-09-2019, 06:52 AM Thread Starter
the lights come on but that's it. It is a security system problem. I tried it so many times that I disconnected the siren that I installed.
antant is offline
post #10 of 18 (permalink) Old 09-09-2019, 01:12 PM
woverby's Avatar
Try a different battery?
2017 FLTRU
