Grounding amp to frame - quick question - Road Glide Forums
post #1 of 3 (permalink) Old 03-01-2012, 05:06 AM Thread Starter
Hi John am installing your 250watt amp on an 11 roadglide custom. Quick question:
Have located the ground stud on the frame near the battery but can't seem to get at it with a wrench. Do I need to remove the battery etc to be able to get to it or is there some trick or tool you guys use? Or is there some other point more easily accessible I can attach the ground?
Any pointers would be appreciated.
Cheers,
JED
JED50 is offline
post #2 of 3 (permalink) Old 03-01-2012, 08:01 AM Thread Starter
NEVER MIND! Just realized it's a 10mm - I've been trying 3/8. Combination of bad eyes and and even worse lighting.
Cheers,
JED
JED50 is offline
post #3 of 3 (permalink) Old 03-01-2012, 08:36 AM
DED HD's Avatar
that sucker is hard to get to huh! glad you got it figured out.
'10 Red Custom:
DED HD is offline
CVO frame powder coat question bowtech40 Paint & Bodywork Section 2 11-20-2014 07:29 AM
amp install quick question motosig102 Audio 1 04-21-2014 08:07 AM
Quick amp question - 2 vs 4 channel Garemlin Audio 9 03-01-2013 07:43 AM
Grounding points for ARC mini amp Airborne314 Audio 5 07-14-2011 03:07 PM
Mid-frame Air Deflectors.....Question Nevadasun *General Road Glide Discussions/Pictures 6 03-31-2011 08:48 AM
