250 watt amp adjustments - Road Glide Forums
post #1 of 5 (permalink) Old 03-13-2012, 10:38 PM Thread Starter
craigv65's Avatar
i have the 7.25 rokkers and the 250 watt amp. i installed everything the way it came. what are the settings for the amp that most are using?
2012 FLTRX
Roland Sands Design Contrast Cut line
Roland Sands Hang-Lo Seat
Roland Sands Glider Bars (TBD)
H-D Edge Cut line
FullSac X-Pipe B
CFR Exhaust (The BEST sounding I ever heard)
Tman TR-600sm cams
TTS Matertune
J&M 7.25 Rokkers with 250 watt amp
Progressive Mono Tube Suspension
craigv65 is offline
post #2 of 5 (permalink) Old 03-14-2012, 01:36 AM
Longrider's Avatar
They don't want you to touch the settings. I was told by John from J&M, if you remove the tape covering the screws to adjust it, it will void the warranty. My tape is gone.
Longrider is offline
post #3 of 5 (permalink) Old 03-15-2012, 02:48 AM
I have the same system (J&M 250 w/ 7.25's). I didnt need to amp-adjust mine as the bass didnt distort at all at max setting. In theory i shouldnt blow a speaker but time will tell.
Fog Shark is offline
post #4 of 5 (permalink) Old 05-05-2012, 08:58 AM
J&M 250 watt amp is going into protect ?
Just installed 250 watt amp and rokker 7.25 speakers and amp is shutting down when I turn radio volume up about a third the way there is no info about the amp other than install instructions. I've double checked my work looks right
There is a two position switch that says preamp or speakers it was set to speakers from the factory. It being Saturday I can't call J&M. Its powers up just fine but when i bring the volume up to a point (not very loud) its just like you hit a mute button the fan on the amp comes on. Its like its going into protect or something. anybody ever have this sort of problem?
Sok Monkee is offline
post #5 of 5 (permalink) Old 05-05-2012, 09:39 AM
JMJOHN
JMJOHN's Avatar
good amplifier adjustment video here http://www.youtube.com/watch?v=Y6C5MiRGq1Y&feature=plcp ,,,,,
JMJOHN ----
JMJOHN is offline
J&M 250 Watt Amp Eddie-Diesel Sold 14 03-16-2013 12:42 PM
J&M 250 watt amp, 7.25 speakers, adapters, bracket, and wiring SEUGOT1 Sold 10 02-25-2013 07:10 AM
J&m rocker 250 watt amp glide69 Audio 3 06-30-2012 01:15 PM
Adjusting a J&M 250 watt amp ironmark J&M 8 05-25-2012 11:10 AM
Fan noise from J&M 250 watt amp DED HD J&M 11 01-06-2012 09:13 AM
