Pre-Programed Amps - Road Glide Forums
post #1 of 3 (permalink) Old 11-05-2014, 07:58 AM Thread Starter
scooterroid's Avatar
Pre-Programed Amps
[email protected]&M:
Since the amps are pre-programed, can a 4-channel amp be programmed for 2-channel output? Also, If you guys do an install do you have the ability to re-flash the stock head unit?
Thanks,
Scoots
scooterroid is offline
post #2 of 3 (permalink) Old 11-13-2014, 05:49 AM
Programming
Thanks,
Scoots
If you have a 4 channel amp like 500W rokker you can just use the 2 front channels for speakers in your fairing. Later you can add the lower or rear speakers at your leisure. depending on which amp 4 Ch with lowers or 4 ch with rear you would buy the JM Dongle to reprogram the amp for the correct location of your speakers if they do not exactley match the original amp specs....
2013 Road Glide Custom Pearl Orange 7-13-2013
cvanmete is offline
post #3 of 3 (permalink) Old 12-25-2014, 03:11 PM
JMJOHN
JMJOHN's Avatar
scooter ,,,,,,,
you can connect a J&M 4-ch amp to just two channels for now until you add the second set of speakers ,,, no harm at all ,,,,
we are not able to flash the Harley radios ,,,,, I believe only your Harley dealer can do that ,,,,
Happy Holidays to you and your family ,,,,,,
JMJOHN ----
JMJOHN is offline
What do pre amps do? bowtech40 Audio 4 07-21-2014 09:24 PM
anyone seen Power Pucks amps? DED HD Aftermarket Accessories 5 11-23-2013 10:06 AM
amps ozbowhunter Audio 19 01-24-2011 05:14 PM
Amps for sale ITOLDU Classifieds Archive (3 months old+) 0 11-09-2010 10:30 PM
