Radio Flash - Road Glide Forums
post #1 of 11 (permalink) Old 08-13-2015, 06:33 AM Thread Starter
Radio Flash
I have a 2015 RoadGlide Special, I want to install the J&M Solo Headset Connection Harness kit 2014-15 Harley Street/RoadGlide HSPT-H14S, does the radio have to be flashed to make it work or is it plug and play. Harleys head set connector part No. 69200865, if you read the install instructions does not mention flash required, dealer says has to be done, rather not do that if I don`t have to.
stevec is offline
post #2 of 11 (permalink) Old 08-13-2015, 07:56 AM
Spazz's Avatar
You will most likely need a flash to enable headset use since the RGS's don't come with a headset like the dresser's do. It's only about a 15 minute process on Digital Tech... as long as the tech knows what he is doing.
Also... you may want to hit up JMJOHN .. he may know first-hand...
RENO BAGGER AUDIO
Spazz is offline
post #3 of 11 (permalink) Old 08-14-2015, 12:36 AM
JMJOHN
JMJOHN's Avatar
stevec ,,,,,,
NO RADIO FLASH needed ,, just plug in this cable HSPT-H14S Product Information to the back of the Harley radio and rock-n-roll, AND be able to answer on screen and talk on your cell phone, all thru the stock Harley infotainment system ,,,,,,
JMJOHN ----
JMJOHN is offline
post #4 of 11 (permalink) Old 08-14-2015, 06:04 AM
Spazz's Avatar
Originally Posted by JMJOHN View Post
stevec ,,,,,,
Good info John... I wasn't sure on the flash....thanks for chiming in
RENO BAGGER AUDIO
Spazz is offline
post #5 of 11 (permalink) Old 08-14-2015, 05:40 PM Thread Starter
well, thanks so much, thats good news
stevec is offline
post #6 of 11 (permalink) Old 08-18-2015, 05:39 AM Thread Starter
well installed com cable last night, turned everything on, selected headphones, dead quite, works fine on speakers, guess it needs a flash after all , at least I know, will make an appointment soon.
stevec is offline
post #7 of 11 (permalink) Old 08-18-2015, 10:31 PM
JMJOHN
JMJOHN's Avatar
Steve ,,,,,,,
did you go into the menu options on the Infotainment radio and switch the music, phone etc to headsets instead of external speakers ? ,,,,,,,,,
JMJOHN ----
JMJOHN is offline
post #8 of 11 (permalink) Old 08-19-2015, 05:14 AM Thread Starter
Steve ,,,,,,,
Yes I did it , I first switched everything over to headset, music,phone,ect. Then back one at a time, hey it happens, I`ll make the appointment no big deal.
stevec is offline
post #9 of 11 (permalink) Old 08-19-2015, 12:24 PM
JMJOHN
JMJOHN's Avatar
Steve ,,,,,,
wow ,,, I have a 2014 Harley Streetglide and 2015 Harley RoadGlide and I did not need to flash either one of them to be able to connect the J&M Headset cable (((here HSPT-H14S Product Information ))) and listen to music and talk on the phone thru the helmet headset ,,,,
and we have installed over 50 of these cables at trade shows just this year, and all of them work perfect without the need to flash anything special into the Harley radio ,,,,,
JMJOHN ----
JMJOHN is offline
post #10 of 11 (permalink) Old 09-07-2018, 11:04 AM
Will the HSPT-H14S work with a Sena Freewire? what is the difference between this and the HD cable that makes the HD one require a flash? Or does the HD one not really require a flash and it's just another way for the stealership to scam us out of $50?
peramus is offline
Magic Box or Biketronics? or Flash No Flash ? Justposts Audio 28 06-14-2018 07:27 PM
To flash, or not to flash Riderdave Do-IT-Yourself 4 10-24-2017 09:19 AM
Flash or no Flash?? 707HYN Audio 8 08-20-2016 01:50 PM
To flash or not to flash onemanpossee Audio 13 12-28-2015 12:54 PM
flash no flash???? buddy75 Audio 1 03-20-2015 11:16 AM
