Would the Amp need to be adjusted? - Road Glide Forums
 2Likes
post #1 of 15 (permalink) Old 11-02-2015, 09:21 AM Thread Starter
I just put in a Aquatic AV unit in my bike does my 250 watt amp need to be adjusted for the new head unit??
post #2 of 15 (permalink) Old 11-02-2015, 09:39 AM
You didn't do that when you had the fairing off ?
Big_gary is online now
post #3 of 15 (permalink) Old 11-02-2015, 09:50 AM Thread Starter
Well it isn't a big deal taking the fairing off/on. Also I didn't want to adjust the amp without knowing what the starting points would be for this head unit.
Also the 250 watt amp adjustments are preset and it may affect the warranty if I do the adjustments.
The only thing that would need to be adjusted would be the wattage input into the amp and the unit sounds pretty good as it is right now.
post #4 of 15 (permalink) Old 11-02-2015, 11:13 AM Thread Starter
Just talked to tech service at J&M and they said no adjustments were necessary the amp is fine with the factory settings.
post #5 of 15 (permalink) Old 11-02-2015, 12:39 PM
JMJOHN
JMJOHN's Avatar
ironmark ,,,,
not sure who you talked to at J&M tech service, but I think there is still confusion here ,,,,,
first of all is your J&M 250w amp a programmable type or does it have regular dial controls ? ,,,,,,
is your new Aquadic radio connected to the J&M amp with direct RCA-RCA cables/connections ? ,,,,,
I will help you get this right ,,,,,,
JMJOHN ----
JMJOHN is offline
post #6 of 15 (permalink) Old 11-03-2015, 08:08 AM Thread Starter
I am just going to get the J&M 500 watt 4 channel amp. I hope it will fix my issue.
post #7 of 15 (permalink) Old 11-03-2015, 09:12 AM
PGR
PGR's Avatar
Now you're talking. I'm running the 4 channel J&M 360 watt with a Jensen. 500 watts would be even better.
I was kind of wondering why you were hooking up an amp rated at 250 watts, on a radio rated at 288 watts.
Ron..........................
PGR is offline
post #8 of 15 (permalink) Old 11-03-2015, 09:40 AM
For the Same reason he thought about adjusting the amp after reinstalling the fairing.
PGR likes this.
post #9 of 15 (permalink) Old 11-03-2015, 11:49 AM Thread Starter
The amp was already there. The 250 watt J&M 2 channel amp and the J&M Rokker speakers have been in the bike for a couple of years.
The Aquatic radio is a 4 channel radio that puts out 288 watts to a 2 ohm system which is 72 watts a speaker.
I wanted to leave the system as it was in the upper fairing which puts out 125 watts a speaker then add lower fairing speakers and run the 72 watts to the lower speakers. Doing it this way I wouldn't need a new amp and the sound should be fairly decent.
But according to the tech at J&M I can't run the amplified signal into the J&M amp from the Aquatic player, I would have to use the non amplified output connections and I would need a splitter with male RCA connections on both ends to make the 2 channel amp drive 4 speakers which would then cut the max power down to 62.5 watts a speaker which is going backward IMO.
So instead of getting the adapter harness for $80 from J&M I decided to go with the 500 watt 4 channel amp which should put 125 watts to all 4 speakers.
post #10 of 15 (permalink) Old 11-03-2015, 06:54 PM
JMJOHN
JMJOHN's Avatar
ironmark ,,,,,,
OK,,, give it a try ,,, but you will get the least amount of distortion using the direct RCA-RCA connection between the Aquatic radio and the ROKKER amplifier ,,,,,,,
JMJOHN ----
JMJOHN is offline
Heal shifter not adjusted correctly Jhl192 Controls & Handlebars 8 10-19-2015 11:15 AM
What do I need to know when looking for an A/C? What would you run in my shoes? kyle31490 Intake and Exhaust 11 03-25-2014 09:03 AM
What amp would I use? LNWLF Audio 6 01-09-2013 03:24 PM
does this belt need to be adjusted BklynRGU *General Road Glide Discussions/Pictures 13 03-08-2012 10:49 PM
New tire, Neck Bearing adjusted twice - Now what? RTWRK *General Road Glide Discussions/Pictures 17 01-02-2012 09:02 AM
