Installed new 500 watt amp and no sound!! Not Happy - Road Glide Forums
 2Likes
post #1 of 17 (permalink) Old 11-06-2015, 07:44 PM Thread Starter
John
I just installed a new J&M 500 watt 4 channel amp in my bike using the Aquatic AQ-MP-5BT-H media player and I have absolutely no sound whatsoever.
This model Aquatic only has 2 output RCA connectors in the rear the other 2 RCA connector are labeled input. As directed I used 2 RCA splitters and split the 2 outputs and hook the splitters to the RCA connector on the amp.
Doing this there is no sound at all to any of the 4 speakers, the green light on the amp is on, all the fuses are good, the remote wire is hooked up, I tried 2 different ground locations, the frame ground first and the battery ground 2nd.
The Aquatic is working because the equalizer is fluctuating and if I unhook the wiring from the amp to the speakers and hook in the front wires from the 23 pin connector I have all sorts of sound.
Either the problem is in the amp or in the Aquatic is there any test I can make to check the system??
post #2 of 17 (permalink) Old 11-06-2015, 08:23 PM
09Sharknose's Avatar
Check the input selector on the amp. Make sure it's set to low level instead of high. Also check the fade on the radio to ensure the rear channels are on. Good luck.
Big_gary likes this.
09Sharknose is offline
post #3 of 17 (permalink) Old 11-06-2015, 08:33 PM
Many new radios have a setting to turn on the RCA outputs. Simple test, go buy a 3.5 to RCA adapter. plug the adapter into your phone and the RCA's into the Amp. Play music on your phone. If the amp plays then the issue is at the stereo, if not its at the AMP.
Sheep Dog is offline
post #4 of 17 (permalink) Old 11-06-2015, 09:15 PM
You might want to eliminate the splitter at first ,just to check your signal. All good ideas above.
post #5 of 17 (permalink) Old 11-07-2015, 12:35 AM Thread Starter
As far as I know there is not a selector on the amp for low level or high level and according to the instructions the amp is preset. Also from what I was told the RCA outputs were for front speakers only and that is why I needed a splitter because I didn't have front/rear fade. I will try setting the media player to rear output and see what happens.
Wasn't using a phone I was just using the radio and I would think that if the system doesn't work on the radio it won't work on a phone.
I tried to eliminate the splitter but no matter what there was no sound no even a crackle or static.
To me it sounds like there is no ground because when I had a ground fail once on my Hogtunes system I didn't get any sound, but I tried 2 different ground locations and the green power light on the amp is on.
It was getting late so I will check everything in the morning and see what happens. I am not sure if it is the amp or the outputs on the media player.
post #6 of 17 (permalink) Old 11-07-2015, 09:42 AM Thread Starter
Went out this morning and checked the fader and it was on full front speakers so I went to full rear speakers and there was no change STILL NO SOUND fader is set in the middle now.
The Aquatic doesn't have any setting to change the output signal.
Checked all the fuses with a ohm meter and they all showed good.
I did check the RCA outputs with a volt meter and with the setting on DCV 200m I was getting 3 volts which is about the same as the output coming out of the 23 pin connector.
post #7 of 17 (permalink) Old 11-07-2015, 10:00 AM
What about the amp? Does it have an input selector? The green light will show as long as it has power. Amos usually have a high(speaker wire)-low(RCA)input selector. The pic below shows it on the Hawgwired RS400. Bottom left corner next to the 3.5mm input jack. ImageUploadedByMO Free1446912045.101048.jpg
post #8 of 17 (permalink) Old 11-07-2015, 10:14 AM Thread Starter
I can see the word input on the amp but if there is a switch it is covered with white tape and from what I understand if I remove the tape it will void the warranty from J&M.
post #9 of 17 (permalink) Old 11-07-2015, 10:20 AM
Smarty's Avatar
Are you sure you are getting power from the switchable power source? Also, check that fuse by the battery. Sling blade theory, no gas?
Smarty is offline
post #10 of 17 (permalink) Old 11-07-2015, 10:45 AM
Oh. Well if your amp is setup for speaker level input and you are running RCA to it, the symptoms are very similar to what you are describing.
Another problem you are going to run into by splitting the rear channels and sending that to your amp and front speakers is that with digital music, all sound doesn't go to the rear channels. Remember the old 5 speaker surround sound home systems. You're sitting there watching a movie and all of a sudden there is sound coming from behind you? That's how your music is going to sound, except you're only going to get the part that is sent to the rear speakers. Now modern audio systems send more than just the scary part to the rears now, but the assumption is always that most sounds originate in the front speakers. I wouldn't expect that recommendation to come from an audio shop.
J&M Rokker XT 500 watt Amp cobra206 Parts for Sale 7 01-07-2017 12:34 PM
J&m rooker 500 watt amp flashing green to red lucky100 Audio 2 05-02-2016 01:25 PM
J & M Install 500 watt system RGS15 Steve Audio 2 10-30-2015 08:11 PM
500 watt rokker amp and boom saddle lid speakers Eshaw301 Audio 1 02-17-2012 09:21 PM
J&M 500 watt amp Peewee Audio 10 01-29-2012 09:03 PM
