Getting Conflicting Info From J&M - Road Glide Forums
post #1 of 5 (permalink) Old 01-31-2013, 08:09 PM Thread Starter
I own a 2013 Road Glide and decided on upgrading the audio with both two additional speakers (placed in new lower fairing) and 500 watt amp from J&M. I subsequently ordered a JAMP-500HR06-RC for my application from an authorized J&M dealer in Arizona. When the amp arrived, I realized the vendor had instead substituted amp JAMP-500HR06-RCR (for a dual rear speaker application). No problem, mistakes happen. So I contact the dealer who advises that she had sent the amp as directed by J&M tech support (updated for either front or rear applications). OK, doing my own due diligence, I download both install diagrams, and while the amp itself appears universal, the wiring harnesses are clearly different. Specifically, the harness for my application (Front lower speakers - RC), patch from the factory HK radio and branch FOUR leads (two pair, front and rear) into the amp, not two. No such harness comes with the RCR setup. OK, no problem, things happen. So I call J&M tech support myself tonight. After getting a tech support rep on the phone and explaining my conundrum, I am also assured that the RCR harness will work for forward speakers..???? Really confused (I suppose I can get a couple RCA splitters and make it work, but not sure I want to do that). In closing, I call the dealer back who intends to call J&M tomorrow (2/1) for clarification...
George
[email protected]
gpdstaffcapt is offline
post #2 of 5 (permalink) Old 01-31-2013, 08:36 PM
Admin
BillyBob's Avatar
John the CEO of j&m is usually on here.
You should post in the j&m section.
BillyBob is offline
post #3 of 5 (permalink) Old 01-31-2013, 10:34 PM
CHAINSAW's Avatar
When I installed the splitter for my front lower speakers, I do remember the instructions not matching up with the wiring harness I got. I just started playing around plugging things together until I got it to work, but I had the same problem when trying to figure it out.
Such is the rule of honor.
CHAINSAW is offline
post #4 of 5 (permalink) Old 01-31-2013, 11:01 PM
JMJOHN
JMJOHN's Avatar
gpdstaffcapt ,,,,,,
I apologize for the incorrect info ,,,,,,,, I am going to whip some tail when I get back to the shop on this very subject ! ,,,,,,,
return the amp kit you have and get the correct one for your application ,,, see http://www.jmcorp.com/ProductDetail....AMP-500HR06-RC ,,,,,,,,
please let me knwo how it works for you ,,,,,,,
JMJOHN ----
JMJOHN is offline
post #5 of 5 (permalink) Old 02-01-2013, 05:17 AM Thread Starter
Thanks...
Thanks John... for the quick response...will do
George NY
Dragos & D&D, couldn't decide so getting both roadie13 Intake and Exhaust 19 01-24-2014 05:05 PM
Getting Amp Dialed in Deadstroke Audio 15 12-28-2013 08:03 PM
Seat screw, clip, & fender sleeve getting lost HELP ! Easyryder01 Seating: seats, backrests 12 09-27-2013 11:20 AM
Anyone regret getting or not getting ABS??? Garemlin *General Road Glide Discussions/Pictures 69 11-27-2012 02:31 PM
Problem with conflicting mods tcon287 *General Road Glide Discussions/Pictures 7 05-28-2011 08:18 PM
