John I need some audio direction - Road Glide Forums
post #1 of 6 (permalink) Old 02-07-2013, 11:51 PM Thread Starter
Eddie-Diesel's Avatar
Hey John,
I have a 2011 RGC. last year i installed the 7.25 fairing speakers with the 250 watt amp. I just had the Harley saddlebag lid speakers installed. I also bought your 500 watt amp. Im in the process of purchasing your saddlebag woofers. How would you hook this up to get the best sound possible? I willing be running it all from the sony dsx 310 radio. HELP PLEASE
Thanks,
Eddie
Eddie-Diesel is offline
post #2 of 6 (permalink) Old 02-08-2013, 06:16 PM
JMJOHN
JMJOHN's Avatar
Eddie,,,,,,,
You would connect the 'J&M fairing speakers together in series with the Harley lid speakers,,,,,,,,, and adjust amp gains on the front channels accordingly ,,,,,
Then connect the rear subs to the rear channels of the 'J&M amp, switch the rear channels to subwoofer mode, and adjust as per our video on that subject ,,,,,,,,
Just let me know how I can be of assistance ,,,,,,
JMJOHN ----
JMJOHN is offline
post #3 of 6 (permalink) Old 02-08-2013, 06:36 PM Thread Starter
John,
Thanks for your quick response. If I wire the speakers as your recommend, will I be getting the 125 watt RMS on each speaker?
post #4 of 6 (permalink) Old 02-09-2013, 08:28 AM
JMJOHN
JMJOHN's Avatar
no ,,,,, the power would be reduced to about 80w per speaker, but you would adjust the gain levels on the amp, to compensate for the change in impedance and actual volume on the highway would be very close to the same ,,,,
take a look at this video http://www.youtube.com/watch?v=NJj7CrxUTts ,,,,,,,
JMJOHN ----
JMJOHN is offline
post #5 of 6 (permalink) Old 02-09-2013, 09:58 AM
Admin
BillyBob's Avatar
Thanks thinking about doing this also
BillyBob is offline
post #6 of 6 (permalink) Old 02-09-2013, 05:59 PM
JMJOHN
JMJOHN's Avatar
BillyBob ,,,,,,,,
personally, I would not do lids and subwoofers together ,,,,,, usually one or the other works the best ,,,,,,
shoot me an email direct at [email protected] and we can talk more about this ,,,,,,,
also remember ,,,,
90% of what you are going to hear at 75+ mph on the highway, is going to be from speakers mounted in front of you, not behind you ,,,,,
I would upgrade your system by the following steps to maximize the sound per $$$ spent ,,,,,
Upgrade the stock fairing speakers first ,,,, ((and of course the J&M 7.25" speakers are a great choice, either the 'J&M Performance series or the ROKKER XT series)) ,,,,,
then add an amp to the upgraded fairing speakers ,,,,,,,, the more power the amp provides, the louder the sound, as a "general" rule ,,,,,
then add lower fairing speakers, the larger the better, and connect them also to the amp ,,,,,, (((a four channel amp connected to the 4 upper & lower fairing speakers will be slightly louder than using a two channel amp of the same power output)) ,,,,,
when you have all of that accomplished, then it makes sense to start putting $$$ into rear pod or saddlebag speakers, subwoofers etc ,,,,
these videos will also offer more information ,,,,,,
http://www.youtube.com/watch?v=UmzDOMX32gA ,,,,,,,
JMJOHN ----
JMJOHN is offline
Need a little direction... r_einan Controls & Handlebars 11 06-14-2017 03:25 PM
This girl needs some direction ..... Ironthrottle883 Do-IT-Yourself 22 04-04-2016 06:30 PM
Kudo's the John and his team at J&M Audio Stick_FSMC Audio 5 03-04-2014 02:49 PM
Harley's new direction - Higher quality or just Higher Profits? Uncle Fuzzy *General Road Glide Discussions/Pictures 25 04-20-2012 06:29 AM
Thinking of taking my bike in a different direction... TracyB *General Road Glide Discussions/Pictures 68 05-02-2011 04:25 AM
