JM speakers/amp with boom audio - Road Glide Forums
post #1 of 6 (permalink) Old 02-12-2013, 03:53 PM Thread Starter
John.
Looking at buying 250 watt amp, Model ESPA-1250, 7 1/4" speakers, model #40-451 (140 watts) with adapters, the bracket to mount.
I have HD Boom audio saddle bag lid speakers and OEM HK head unit with the appropriate harness.
Is this amp sufficient to drive these four speakers? Any special wiring/harnesses I need to hook up?
Thanks Steve
platinum69 is offline
post #2 of 6 (permalink) Old 02-12-2013, 06:39 PM
Admin
BillyBob's Avatar
I believe so . Check with John under the j&m section. He'll help you out.
BillyBob is offline
post #3 of 6 (permalink) Old 02-12-2013, 06:51 PM Thread Starter
This is the JM section....
post #4 of 6 (permalink) Old 02-12-2013, 10:57 PM
JMJOHN
JMJOHN's Avatar
Platinum69 ,,,,,
does your front/rear fader currently work on your HK radio between the fairing speakers and rear lid speakers ? ,,,,,,
I will help you get this right ,,,,,,,
JMJOHN ----
JMJOHN is offline
post #5 of 6 (permalink) Old 02-13-2013, 06:50 AM Thread Starter
Originally Posted by JMJOHN View Post
Platinum69 ,,,,,
John, yes, it was a software fix done at the dealer.
Steve
post #6 of 6 (permalink) Old 02-14-2013, 08:46 AM
JMJOHN
JMJOHN's Avatar
Platinum69,,,,,,,,,
the Harley BOOM speakers will have a hard time staying reliable when connected to the large J&M ROKKER amps, featuring 125w RMS per channel, into 2 ohms ,,,,,,,
take a look at this new J&M performance amplifier series we are releasing in March that feature 90w RMS per channel output ,,,,,, both two and four channel versions will be available ,,,,,,
not only are they significantly less expensive than the current ROKKER series, their slightly reduced power output will be easier on the harley BOOM speakers ,,,, yet sound and performance will be surprisingly close to the J&M ROKKER series ,,,,,
here is a sneak peek http://www.jmcorp.com/ProductDetail....=JMAA-1800HC06 ,,,,,,,,,
I would recommend one of the new 4-channel J&M amps, so that your front/rear fader capability is maintained ,,,,
JMJOHN ----
JMJOHN is offline
JM Rokker VS Boom audio fyreftr Audio 6 09-26-2013 06:29 PM
J & M Performance Speakers 7.25" and Boom Audio Amp baghrd Sold 5 12-01-2012 10:14 AM
7" jm speakers w/boom amp skymech9 Audio 0 06-09-2012 01:25 PM
Boom!™ Audio High Performance Boom!™ Bagger Road Glide® Fairing Speakers longrides Classifieds Archive (3 months old+) 1 11-14-2011 07:01 PM
JM 7.25 and elf audio amp tjs529 Audio 6 05-19-2011 04:23 AM
