Is there anything wrong with... - Road Glide Forums
post #1 of 1 (permalink) Old 07-03-2013, 08:40 PM Thread Starter
installing an inline (water proof) switch (mounted in the glove box) in the trigger wire of the Rokker 500w amp, so that I have the option of turning the amp on / off when I am listening to the head phones, Bluetooth, or whatever, while riding ~ the '09 SERG came with the speaker switch in the dash.
Or could I just wire it to work off the speaker switch in the dash? Is it a pita to wire it into the speaker switch on the dash ~ do I have to butcher the wiring harness?
'Am running preamp outs on the HK if that makes any difference.
'Wanted Iron Cross Audio to install a trigger wire in the HK, they said it really wasn't possible, as there is no switched 12v source in the HK to tap into.
HeatWave is offline
Is there anything wrong with this photo? twowheeladdict General Off-Topic Discussions 42 10-05-2017 05:50 PM
See anything wrong with this ad? Wild Child *General Road Glide Discussions/Pictures 15 04-04-2015 03:29 PM
Is there anything to cover up the lower fairing bolt? trbo2nr *General Road Glide Discussions/Pictures 9 03-12-2015 01:07 PM
Is there anything to help with trans clunking and top end noise garzajr676 Engine Related 16 12-14-2013 04:25 PM
Levers, is there anything other than stock LPFRAY Controls & Handlebars 8 10-24-2010 01:50 PM
