Tips on removing Sancho Wings - Road Glide Forums
post #1 of 5 (permalink) Old 12-12-2011, 09:50 PM Thread Starter
I have a broken Sancho wing and I need to replace it but I would like to know if anyone has removed their Sancho Wings and if the 2 sided tape damaged the paint when it was removed. I was thinking that heating the tape with a hair dryer would help, but I would like some suggestions.
post #2 of 5 (permalink) Old 12-12-2011, 10:05 PM
Heat it up then use waxed dental floss or fishing line to "saw" under the wing (breaking the adhesive). Should come right up. You can use Goo Gone (or anything similar) to remove the remaining adhesive. I've debadged cars, trucks and bikes (including my own) many times this way. Never had a paint issue that wasn't already there.
Monkeyman is offline
post #3 of 5 (permalink) Old 12-13-2011, 02:10 AM
Sancho's Avatar
I've taken mine off time after time using this method and never had a problem.
Your Wings may be removed by removing the screw. After removing the screw stand beside your Road Glide, facing forward, and pulling the Wing towards you. The tape will stick to the deflector and must be replaced when re-installed using 3M Super Strength Molding Tape, part # 03614, available at any automotive store.
Sancho is offline
post #4 of 5 (permalink) Old 12-13-2011, 02:53 AM
I was thinking of something else. Disregard my previous post. :0
post #5 of 5 (permalink) Old 12-13-2011, 01:32 PM
If you have a painted inner fairing, a lot depends on the quality of the underlying paint.
SickRick is offline
Welcome Sancho's Wings BillyBob Sancho's Wings 36 12-02-2013 08:21 PM
sancho wings wind deflectors. dres22 Windshields 5 11-09-2010 08:38 AM
Sancho's Wings Web site Sancho Aftermarket Accessories 3 10-27-2010 10:57 PM
Sancho's Wings again.... dblkick Aftermarket Accessories 4 10-05-2010 09:53 AM
Sancho's Wings Fairing Air Deflector Sancho Aftermarket Accessories 14 08-22-2010 07:34 PM
