21" wheel install - Road Glide Forums
post #1 of 17 (permalink) Old 08-11-2016, 07:25 PM Thread Starter
emptyking's Avatar
21" wheel install
Question for all. I'm looking to put a 21 on my 08 RG, and I'm just curious what all is needed to do an install? I was reading about a lowering kit for the front to help with stability, but is that necessary? And what all do I have to do to my stock fender? And help would be great thanks
emptyking is offline
post #2 of 17 (permalink) Old 08-11-2016, 07:47 PM
ERod62's Avatar
It is recommended to lower the front one inch but not required know couple friends that did not lower front end riding 21" and rides as good as stock set up.
Fender may need to drill back mounting holes to 3/8 tipping the fender up for clearance. Also know of some cases didn't need to drill.
You can put a 3/8 nut on top of the 21" tire if runs through no need to drill the fender.
Good luck.
ERod62 is offline
post #3 of 17 (permalink) Old 08-11-2016, 08:30 PM
Life Member With a Grey Beard
SharknoseScott's Avatar
Good luck.
What he said. I didn't lower the front (but I am 6'2"). Drilled the holes to adjust the front fender. Works great.
Once I make up my mind, I'm full of indecision.
SharknoseScott is offline
post #4 of 17 (permalink) Old 08-11-2016, 08:33 PM Thread Starter
emptyking's Avatar
Awesome thanks guys.
post #5 of 17 (permalink) Old 08-11-2016, 08:33 PM Thread Starter
emptyking's Avatar
Any recommendations on wheels? Where to go?
post #6 of 17 (permalink) Old 08-11-2016, 08:41 PM
James's Avatar
I didnt need to drill my fender.
I would call hogpro and tell them you are forum member, ask what kind of deals they can give you. They treated me very well when ordering several parts.
Another choice is wanaryd wheels, similar prices to hogpro.
James is offline
post #7 of 17 (permalink) Old 08-11-2016, 08:48 PM
Did not lower my 08 when I did 21 on it and did have to drill the fender. Got my tire and wheel package from Eastern Performance.
DuraGlide is offline
post #8 of 17 (permalink) Old 08-11-2016, 08:57 PM
NDfan's Avatar
If you have any rallies close by or plan on attending one, they usually have vendors set up and will do mount, install and balance for special rally prices. FTD Customs (Harley wheels, Rinehart Exhaust, Hayabusa Swingarm Extensions, GSXR swingarm extensions, zx14 swingarm extensions, Vance and Hines exhaust, free same day shipping in the USA.) has a good selection and great service. They do their own wheels from start to finish and totally stand behind their work. Amazing group of folks to work with.
NDfan is offline
post #9 of 17 (permalink) Old 08-11-2016, 09:04 PM Thread Starter
emptyking's Avatar
I have seen FTD and I like that they have a lifetime warranty.
post #10 of 17 (permalink) Old 08-11-2016, 09:14 PM Thread Starter
emptyking's Avatar
Do you have a pic of your bike?
21" 23" or 26" Wheel rconnor Wheels and Tires 11 07-12-2015 10:03 PM
21" wheel with -2" mono tubes SIC_26 Suspensions 0 06-04-2012 06:19 PM
21" wheel with stock back wheel Cybrrmage Aftermarket Accessories 16 11-12-2011 11:50 PM
21" wheel w/ 13" rotor vs. stock calipers v-rodder *General Road Glide Discussions/Pictures 7 08-11-2011 11:11 AM
