Ride on tire sealant and balancer - Road Glide Forums
 3Likes
post #1 of 17 (permalink) Old 09-06-2016, 12:06 AM Thread Starter
bigshaqa's Avatar
Well I tried the stuff but for me didn't work. Didn't seal the tire at all. Seems to be in the target area for it to seal. I did exactly as the website say but still the stuff didn't seal the puncture. Just my experience.
PEOPLE SEE ME BUT THEY JUST DONT KNOW
bigshaqa is offline
post #2 of 17 (permalink) Old 09-06-2016, 01:04 AM
It's hard to see from that picture but the hole appears to be towards the side of the tire. The ride on seals only the contact patch of the tire. Basically the center maybe out about an inch. I use it in my tires but fortunately I haven't and anything in my tire yet. I will however be replacing the rear tire very shortly because it's worn out so I'm gonna "test" it myself by drilling 1/8 holes to see what happens
roadglidetouring likes this.
post #3 of 17 (permalink) Old 09-06-2016, 10:15 AM
twowheeladdict's Avatar
Please provide a little detail.
How did you notice that the tire was punctured?
Did the tire go flat while riding it?
Were you checking the air pressure and it was almost flat?
Did you notice the nail and pull it?
For the sealant to work correctly the bike should be moving so the sealant can get to the hole, or the hole needs to be at the lowest point on the tire.
Example: if you noticed the nail and pulled it before checking the tire pressure you really don't know if the tire sealant worked or not.
twowheeladdict is offline
post #4 of 17 (permalink) Old 09-06-2016, 12:14 PM
BlazingSaddle's Avatar
^--- This.
Also, unless your sealant is white in color, (the one's I've used in the past were generally fluorescent green or orange) I don't even see where any sealant even attempted to plug that big a$$ed hole.
As twoweeladdict said, need more details besides that you did it exactly as the website said. A key detail is missing. My experience with sealant is it works long enough to hobble into a repair shop for a replacement. I have had instances where the hole was too big and as rlaf75 said, if it's too close to the sidewall, it won't work.
BlazingSaddle is offline
post #5 of 17 (permalink) Old 09-06-2016, 12:57 PM
Bandit 7's Avatar
I may be missing something here but it sounds like you attempted to use the ride-on after you had a puncture, if so that's not how it's designed to be used. I use it at every tire change with good balancing results and have had one puncture that sealed after removing the nail as advertised.
Bandit 7 is offline
post #6 of 17 (permalink) Old 09-06-2016, 01:09 PM
thealaskan's Avatar
I carry a tire repair kit and a small compressor. You can also get the kits with Co2 canisters... easy peazy. I fixed a flat years ago that way and rode it another 6 or 7k until it was time to change. I carry this compressor, powerful enough to fill a truck tire or an air mattress: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Swomack likes this.
When you come to a fork in the road, take it. -- Yogi Berra
thealaskan is offline
post #7 of 17 (permalink) Old 09-06-2016, 01:16 PM
thealaskan's Avatar
Incidentally, for anyone thinking they might get by cheap, H-D will not repair any tire.
post #8 of 17 (permalink) Old 09-06-2016, 01:27 PM
Local dealer quoted me $1000 for new tires and mounting.
Tires will cost me $322.87 and my time to mount them.
post #9 of 17 (permalink) Old 09-06-2016, 01:31 PM
That is great after the fact. The ride on is supposed to keep you from having to plug a flat on the side of the road. The caveat though is that you have to inspect your tires frequently for foreign objects that might further damage the tire.
post #10 of 17 (permalink) Old 09-06-2016, 01:59 PM
Bandit 7's Avatar
That's exactly why I buy my tires else where and mount them myself. Front and rear Michelin Commander IIs with enough ride-on for both less than $400 from Revzilla.
Distance likes this.
Bandit 7 is offline
Ride On Tire Sealant jchar27 Sold 2 05-30-2014 01:44 PM
anyone use ride on tire sealant/balancer? slinger Wheels and Tires 18 04-16-2014 10:47 AM
Ride On tire balancer/sealer rlaf75 Wheels and Tires 21 11-01-2013 06:33 PM
Ride on dynamic tire balancing and sealant bpt-bagger Equipment-RG 4 01-03-2013 09:23 PM
Ride-On Tire Sealant Laconia Wheels and Tires 7 09-26-2012 09:15 PM
