Warped rotors - Road Glide Forums
 3Likes
post #1 of 17 (permalink) Old 09-08-2016, 02:04 PM Thread Starter
glidethru's Avatar
Warped rotors
Are any of y'all having problems with your front rotors warping on aftermarket wheels, i will soon will be on my third set on a front wheel a little over 2 years old. The company I bought them from have been good about replacing them,,,but damn I either have to pay someone to replace or do it myself, getting kind of aggravated
MAGNA FLOW "Top Guns
Wild Ones 12" Chubbys
glidethru is offline
post #2 of 17 (permalink) Old 09-08-2016, 02:09 PM
seetiggergo's Avatar
Are you running 1-piece rotors or 2-piece floating rotors with your aftermarket wheels? Just curious.
'08 Harley Road Glide - Iron Aces Mount - Too many other upgrades to list!
seetiggergo is offline
post #3 of 17 (permalink) Old 09-08-2016, 02:39 PM
Joe456's Avatar
I have renegade rotors and having a problem with them also there 2 piece rotors can just the outsides be replaced or the whole rotor
2012 Fltrx BBP with some black stuff
Joe456 is offline
post #4 of 17 (permalink) Old 09-08-2016, 02:58 PM
I know that with RC Components 2-Piece Rotors one can purchase the replacement "outer ring" (braking surface) of the rotor but am not sure if Renegade offers this option. The only thing that would concern me about replacing only the braking surface is not knowing what on the 2-Piece Rotor is actually warped, is it the braking surface and/or the decorative center...if it's the center that is warped, then I'd think that replacing the just braking surface would not eliminate the issue.
post #5 of 17 (permalink) Old 09-08-2016, 03:50 PM
ERod62's Avatar
Yes, many warped rotors even on stock wheels prior Rushmore, then HD changed to tandem braking system instead fixing the calipers piston issues. The problem is when brake the pistons don't releasing the pads pressure against rotors eventually over heating and warping. Go after market like PM calipers if you are tire of changing rotors. Expensive but will take care of the problem.
Also can clean the calipers with brake fluid very often, pain in the neck specially if like to ride a lot.
Good luck.
ERod62 is offline
post #6 of 17 (permalink) Old 09-08-2016, 05:23 PM
BlazingSaddle's Avatar
The wheel could be the culprit, but I doubt it. I'm wondering if the brake pads were changed out when you swapped out the "bad" rotors. If not, could be the source of your problem. Ideally, your new rotors should be bedded in properly with new pads, and there's a right and wrong way to do it. Also, did you actually check the runout or are you just going by the pulsating feel when you apply the brake? What you're feeling might just be what's called "judder", again, caused by the pads not bedded correctly to the rotor.
BlazingSaddle is offline
post #7 of 17 (permalink) Old 09-08-2016, 07:35 PM Thread Starter
glidethru's Avatar
When they sent new rotors, they also included, pads to change out as well, also I had the wheel checked for run-out and it was fine...regarding the issue with the pads are not releasing I have not heard of that, but i have been told that the Brembo brakes are very good about releasing ..
post #8 of 17 (permalink) Old 09-08-2016, 08:42 PM
I should have been more clear. I was asking if your "warped" disks were checked for runout, as they're sitting on the hub. Rotor runout will cause uneven wear, eventually causing thickness variation which will also cause that pulse you're probably feeling. Since your wheel is true, and if runout on the disks is minimal, I would suspect either pads aren't bedding correctly, or as ERod62 said, calipers might be causing pads to drag. The calipers dragging would be an easy diagnosis, put the bike on a lift and give your wheel a spin preferably right after a ride. I would also ask who did the work, and was everything torqued to specs? Hopefully someone else can chime in. BTW, my then brand new 13 RGU had discs replaced at first service.
reds4 likes this.
post #9 of 17 (permalink) Old 09-09-2016, 10:11 AM
SurlyBoy's Avatar
I've had stock rotors warp on 2012 and 2014 wheels. I got a set of take offs cheap so I'm going to run those for now but after that I'm going to floating ones. Most likely aftermarket
SurlyBoy is offline
post #10 of 17 (permalink) Old 09-09-2016, 10:47 AM
Warped rotors are a common problem. I went with HD floating rotors 5 years ago and I still have them on my bike never needed to replace them, so maybe you should try the HD floating rotors instead of the aftermarket rotors.
The front rotors are thinner then the rear rotor and that's why there is hardly ever reports of warped rear rotors. Also over use of the front brake can cause front rotor warpage, maybe you should try to do a more controlled braking by looking ahead and using the engine by downshifting and using the rear brake and use the front brakes for the times you need to stop quicker.
Mike U and SpazerWolf7 like this.
More warped rotors SurlyBoy Wheels and Tires 14 08-14-2015 03:14 PM
Sick of warped stock rotors? Galfer wave rotors are here! HogPro Wheels and Tires 20 11-25-2014 07:44 PM
2nd set of warped PM rotors this year SMSgt B *General Road Glide Discussions/Pictures 7 11-09-2014 05:11 PM
Warped brake rotors Kudu40 Wheels and Tires 21 09-22-2014 11:40 AM
Warped HD Rotors at 5k miles DOOFUS Wheels and Tires 6 11-05-2012 11:53 AM
