Pressure behind that Nut - Road Glide Forums
 2Likes
  • 2 Post By BlueBagger12
post #1 of 7 (permalink) Old 09-13-2016, 07:53 PM Thread Starter
If you, as many have put 90ies
on.
Was sure it was tight 800 miles ago before skipping out. Least one thread loose when just ck'ed air.
It was 6# lower than before, to be fair the front was 4# lower too.
Time to check yourself
reds4 is offline
post #2 of 7 (permalink) Old 09-13-2016, 08:27 PM
BlazingSaddle's Avatar
Good catch Reds4. I've never used these, and don't know much about them. Is there a reason you couldn't or shouldn't put some blue Loctite on the threads, and then tighten them down, or did you do already do this, and they backed out anyway?
BlazingSaddle is online now
post #3 of 7 (permalink) Old 09-14-2016, 08:12 AM
skratch's Avatar
i just use the 12'' valve extension from hd. never an issue with that.
skratch is offline
post #4 of 7 (permalink) Old 09-14-2016, 09:40 AM
BlueBagger12's Avatar
Tried those stems before nad had same problem. I had much better luck with these: Solid Billet Motorcycle Tire Valves! 82° Stem!
reds4 and shrknz like this.
Don't fail us now, oh blessed mother of acceleration...
BlueBagger12 is offline
post #5 of 7 (permalink) Old 09-14-2016, 09:45 AM Thread Starter
I know or think kow the Al valve stem is grommeted, the nut secures down on the outer rim hole rubber, so the 90 can be laterally positioned . Don't wanta over crank it against the Al rim
reds4 is offline
post #6 of 7 (permalink) Old 09-14-2016, 09:51 AM Thread Starter
Is that like a Zero Loss adapter?
reds4 is offline
post #7 of 7 (permalink) Old 09-14-2016, 12:18 PM
skratch's Avatar
it isn't really zero loss, but i have taken it off and then turned around and stuck it right back on to test how much air it did lose. my digital pressure tester did not measure any loss.
skratch is offline
Replacing seat nut.... akjeff Seating: seats, backrests 3 05-21-2011 07:51 AM
well nut restore ROADEAGLE Windshields 26 03-10-2011 09:39 PM
Nut & bolt compartment shermanator *General Road Glide Discussions/Pictures 1 01-16-2011 04:33 PM
well nut solution ?? JacktheBagger Troubleshooting for Road Glides 9 08-03-2010 09:53 PM
Windshield nut fell back into shark nose? ToddTribe Troubleshooting for Road Glides 20 05-15-2010 08:27 AM
