Darkside tire size??? - Road Glide Forums
 32Likes
post #1 of 36 (permalink) Old 09-14-2016, 12:51 AM Thread Starter
I'm not looking for the "normal" darkside debate so please if you haven't put a car tire on the bike then please keep your comments to yourself so we don't have arguments. Thanks.
With that said, I'm 99% sure I'm gonna make the swap this off season so I'm looking for info on what you darksiders use for tires, brands and sizes. I'm looking to try to keep my speedo as accurate as possible but I see that some use a 195 tire up to 205. I'd also like to keep the tire as rounded as a car tire can possibly be on a motorcycle. Any info is greatly appreciated because you know I don't want to "spontaneously combust"
Mtguns likes this.
post #2 of 36 (permalink) Old 09-14-2016, 07:34 AM
Ran several car tires on a couple of Honda's. Been a long while since I've been there but Delphi Forums has a board for Darksiders for all makes of bikes. I always liked the run flat option.
NMRoadrunner is offline
post #3 of 36 (permalink) Old 09-14-2016, 11:37 AM
gsbuick65's Avatar
I'm gonna use the 195 since it's closer to the OEM size, I ran the 205 on my vtx thought it was to wide but looked cool 😀
Sent from my LG-H740 using Tapatalk
Mike Southaven Ms. 2011 RGU merlot, Rinehart true duals, s&s 570 cams, Power Vision stage 1 a/c, Madstad shield, J&M 7 1/4's, Alpine KTP445U amp, CVO lowers.
gsbuick65 is offline
post #4 of 36 (permalink) Old 09-14-2016, 05:13 PM Thread Starter
Yeah I was thinking about the 195 but I'd like to hear what others are using too. I'd like to hear the pros and cons of the different sizes
post #5 of 36 (permalink) Old 09-14-2016, 05:39 PM
Mike U's Avatar
Rob, there's an earlier thread started by HarleyJack re: Darksiding.
tdkkart posted this link for car tire sizes.
Darkside Tire Info Center
Hope this helps.
Mike U.
rlaf75 likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #6 of 36 (permalink) Old 09-14-2016, 07:16 PM
Rlaf75 , let me know if you feel the CT lowers the rear at all due to the flatness of the tread compared to the rounded mc tire.
Big_gary is online now
post #7 of 36 (permalink) Old 09-14-2016, 09:41 PM Thread Starter
This isn't something that's gonna happen this year for me and I also have the monroe air ride in the back so my ride height varies already. I will do my best to keep up updated though . From some research Ive done I found that there is a CT that's pretty close to the diameter of the Mc tire. I just don't remember what it was
post #8 of 36 (permalink) Old 09-14-2016, 11:32 PM
tdkkart's Avatar
Go look at this thread and you'll see that I used a 205 tire on my '11 Ultra, and it was only 1/16" larger in total circumference than the OEM tire which has approx. 8000mi on it.
https://www.roadglide.org/98-wheels-t...-darkside.html
tdkkart is offline
post #9 of 36 (permalink) Old 09-15-2016, 01:38 PM
glide69's Avatar
Rob,
I'm running a Goodyear Eagle Sport 195/55/16 since I did the 124". I figured a better performance tire would put the 130+ hp to the ground better. With the 103 I ran a Yokohama- Avid Ascend? If I remember correctly witch worked well with the 103. This will help you as far as matching a size to what you have on the bike now. I'm not sure what the stock tire size was on a 09? https://www.tacomaworld.com/tirecalculator I used this and it's pretty damn accurate my speedo is only off by a couple mph.
rlaf75 likes this.
2018 FLTRXS Wicked Red
glide69 is offline
post #10 of 36 (permalink) Old 11-08-2016, 03:43 PM
Drifter -11's Avatar
Cool
I am running a Yokohoma 195/60/16 usually between 30-34 psi depend on load and I run 2 up 98% of time.
I heard after I started running it that the 195/60's have a wobble. I have to say yes upwards of 90mph. But the 195/55 not so much if any from what I heard.
I do it again I am going 205/55.
Brand there are several. You can find info on the Delphi forum and on the Harley Forum under the This and That section look for Darkside.
2011 FLTRX - Totaled,
Cager
2013 FLTRU - Current
Patriot Guard Rider - Brazos Valley/Southeast Texas
Drifter -11 is offline
Officially on the darkside......... tdkkart Wheels and Tires 131 07-15-2019 03:42 PM
1,200 mile Darkside report and questions Boatnut Wheels and Tires 30 04-30-2014 05:41 PM
Darkside tire for sale WolfieD Parts for Sale 8 09-30-2013 01:54 AM
My Darkside Experience masonc Wheels and Tires 29 09-30-2013 12:33 AM
The DarkSide! Neano62 Videos 2 11-18-2010 10:59 AM
