Newer wheels on a 08 Glide - Road Glide Forums
post #1 of 11 (permalink) Old 12-23-2016, 04:10 PM Thread Starter
Are any of the newer wheels able to work on an 08 glide ? Thanks
shrtyonasprty is offline
post #2 of 11 (permalink) Old 12-23-2016, 04:53 PM
skratch's Avatar
front wheels yes, with bearing swaps. rear wheels, nope.
skratch is offline
post #3 of 11 (permalink) Old 12-23-2016, 08:28 PM
^^what he said^^
post #4 of 11 (permalink) Old 12-24-2016, 09:04 AM
No need to swap bearings on an 08 front. First year for the Brembo brakes and 25mm axle. Only need to change out an ABS bearing if needed. Rear wheel has to be 08 and earlier though so it limits your choices if you want them to match.
DuraGlide is offline
post #5 of 11 (permalink) Old 12-25-2016, 07:56 AM
I believe you can only use a 08 rear wheel on your bike without making modifications. 2008 was the first year of the rear wheel compensator or cush drive as it is sometimes called, the 07 and earlier bikes do not have this feature and even though the 09 and later bikes do have the rear wheel compensator the compensator rubbers are a different design and the wheels are wider, to make any 09 and later wheels work you would need a wide tire kit installed on your bike. You can make the 07 and earlier wheels work but you would need to change axle bearings and rear drive pulley. You should be able to find some nice wheels that are made just for your year bike. There is also wheel exchange companies out there that take the stock wheels and chrome them, I got the 08 Street Glide chrome wheels on my bike and they look great, I got them from chrome exchange, chrome wheel exchange, wheel spacers, Harley chrome wheels, Harley trike wheels, trike wheels, hub saver, harley wheels
post #6 of 11 (permalink) Old 12-25-2016, 12:50 PM
The bare rear wheel is the same from 02-08. Brake rotor, bearings and pulley are different on the 08 but will bolt on and press in the older rear wheels. We put both my 08 wheels on my buddies 05 using his rotors and pulley and a set of 08 axles and nuts.
post #7 of 11 (permalink) Old 12-25-2016, 01:01 PM
The rear wheels are not the same because the 08 has the compensator housing casted in the wheel, the 02 -07 wheels are the same. As stated you have to use the 08 pulley and 25mm axle and bearings to make it work on older bikes. But I think the op wants to put a wider wheel in the rear.
post #8 of 11 (permalink) Old 12-25-2016, 02:06 PM
RFG7680's Avatar
I put a 18 off an 11 on my 08. My 08 was non ABS so I got a non ABS wheel and it bolted right up. No issues.
RFG7680 is offline
post #9 of 11 (permalink) Old 12-25-2016, 03:26 PM
Your 08 and my 08 must have been made differently. The IDS pulley on mine was completely bolt on. The rear wheel carried the same part number from 06 (when it was introduced) to 08 on the SG rear wheel. And the 08 SG rear wheel is happily living on my buddies 05 Ultra with his original 05 pulley and 05 brake rotor bolted on. We elected to replace his axles with 08 ones as I had recently replaced the bearings in the wheels I traded him. I also had an 08 Ultra Classic with the same bolt on IDS pulley on the original "wagon wheel". Wider rear wheels will definitely require some "modifications"
post #10 of 11 (permalink) Old 12-26-2016, 12:01 PM
That's correct the 08 pulley bolts on to the rear wheel compensator then the pulley/compensator assembly mates with the compensator pockets that are molded in the rear wheel. Just as long as you use the complete assembly then you're OK if you use a 08 rear wheel on earlier models. There isn't any problems with the front wheel fitment.
Seats for '08 and newer touring bikes ISprayCandy Parts for Sale 3 09-16-2015 12:55 PM
ThunderMax TracMax for 2014 and newer ABS bikes for big wheels HogPro Wheels and Tires 2 01-14-2015 10:18 AM
08' Ultra Tour pack to 08' Road Glide Chain Link Aftermarket Accessories 2 03-02-2013 05:17 AM
Wheels, wheels, wheels, chrome, black, both, whatever post em up! zuppy51 Wheels and Tires 33 10-24-2012 08:46 AM
08 street glide wheels to 05 RG??? VoiceofEFC Wheels and Tires 0 03-25-2012 05:58 PM
