Torque values for 2015 Road Glide front end - Road Glide Forums
post #1 of 3 (permalink) Old 07-24-2017, 08:00 PM Thread Starter
I'm looking for the torque values for a 2015 Road Glide Special. Front calipers bolts, axle pinch bolt and the axle nut
TIA
kws15off is offline
post #2 of 3 (permalink) Old 07-24-2017, 08:25 PM
Smokey's Avatar
Front caliper bolts 28 - 38 ft-lbs
Front axle pinch bolt 18 - 22 ft-lbs
Front axle nut 70 - 75 ft-lbs
Smokey is offline
post #3 of 3 (permalink) Old 07-24-2017, 08:26 PM
RGKen's Avatar
Here's the procedure just in case...
Slide axle through right fork and external spacer into wheel hub.
Push axle through front WSS (if ABS equipped) or second external spacer, and left fork.
Install flat washer and axle nut.
ABS models: Rotate WSS until it contacts rear of fork slider. Back off just enough to maintain clearance between the WSS wire stem and fork slider.
Hold axle stationary and tighten axle nut to 94.9–101.7*N·m (70–75*ft-lbs).
Push and hold right fork slider inboard until it contacts external spacer. Tighten axle pinch screw to 24.4–29.8*N·m (18–22*ft-lbs).
Front Brake caliper mounting bolts 28-38 ft lbs
2018 FLTRXS
RGKen is online now
2015 Shark=bad values for ours DOOFUS *General Road Glide Discussions/Pictures 103 12-24-2014 11:53 AM
Power Vision "Fuel Trim Values"? bear25314 ECM/Fuel Management systems 10 11-24-2013 01:38 PM
Bike Values srs64 General Off-Topic Discussions 17 05-27-2012 02:14 AM
Tourque Values??? Ernster500 *General Road Glide Discussions/Pictures 3 05-08-2012 10:05 PM
Torque Values lldsilver41 Troubleshooting for Road Glides 3 01-23-2011 08:27 PM
