200 rear tire - Road Glide Forums
post #1 of 2 (permalink) Old 09-24-2017, 01:02 PM Thread Starter
200 rear tire
Anyone running a 200 rear tire on a 2011 cvo roadglide?
hemi1966 is offline
post #2 of 2 (permalink) Old 09-24-2017, 02:56 PM
twowheeladdict's Avatar
Why?
Unless the wheel is designed for that width tire you are pinching the tire to fit on the rim. That means you are changing the profile of the tire which in turn reduces the contact patch.
If you are staying with the same ratio then the diameter is larger which in turn changes the handling a little. Makes turn in quicker by raising the rear which changes the rake and trail a little.
Will it be noticeable on the Road Glide? Depends on how you ride.
twowheeladdict is offline
When is a 200 X 55 X 17" tire not a 200 x 55 x17?Son of a ..... Uncle Fuzzy *General Road Glide Discussions/Pictures 5 07-17-2016 09:13 PM
200 rear tire on a 09 and up? FUGLY *General Road Glide Discussions/Pictures 7 04-12-2015 06:25 PM
200/50/ZR17 Metz vs 200/55/17 Commander 2 mrnitrous Wheels and Tires 2 06-05-2013 08:14 AM
200 rear tire wobble W_D_R Wheels and Tires 5 04-25-2013 12:27 PM
Who's running a 200 Rear tire SIG556 Wheels and Tires 13 12-05-2012 05:40 PM
