wider front tyre - Road Glide Forums
post #1 of 3 (permalink) Old 10-03-2017, 02:50 PM Thread Starter
Slimboybinz's Avatar
wider front tyre
I am about to get a new front tyre for my 2016 RGS.
How much wider can I go without changing the rim or anything else?
Thanks
SLIM
Slimboybinz is offline
post #2 of 3 (permalink) Old 10-09-2017, 11:12 AM
G3Viper's Avatar
If you stay with stock rim you can only go 150 but Native Customs sells what they call their Pitbull kit I think it?s $600 you are able to get a 18x5.5 rim and go to 180 which is a truer fat tire front. The kit has a laser cut fender and cowbells that are also cut so they slide inside the fender this way you do not have to go with their $1300 kit where you can go to 200 but that has more work to be done it comes with trees to make front end wider. Hope this helps I am going with Pitbull and I will need to get a wider rim for a 180x55. I know you can use some rear tire rims but I do not know which ones will work.
G3Viper is offline
post #3 of 3 (permalink) Old 10-09-2017, 04:04 PM
wevsspot's Avatar
Just to clarify........
The $599 NB Pitbull kit is for 1984-2013 bikes.
The OP would need the NB Pittbull kit for 2014+ HD Touring bikes. That one starts at $899.
https://www.nativecustombaggers.com/...4-present.html
wevsspot is offline
200 rear tyre Slimboybinz Wheels and Tires 4 01-04-2018 09:13 AM
Wider Tire Up Front? sometimer Wheels and Tires 12 08-14-2016 11:30 PM
Wider 19" front tire? madmat Wheels and Tires 0 08-14-2016 08:32 PM
wider tire on the front ??? kenstephens Wheels and Tires 34 05-27-2015 07:44 AM
Tyre To Travel with iPhone/Navigon? elbohead GPS 2 05-24-2015 09:19 AM
