warped front rotors - Road Glide Forums
 12Likes
post #1 of 34 (permalink) Old 10-03-2017, 02:59 PM Thread Starter
Slimboybinz's Avatar
warped front rotors
I have just been told by my dealership that both of my front rotos and both sets of brake pads need to be replaced due to the rotors being warped.
My bike has only 12,000 Km (7000 miles) .
dealer says they are not covered on warranty.
are these crappy discs made in China, and what are your thoughts on this?
SLIM
Slimboybinz is offline
post #2 of 34 (permalink) Old 10-03-2017, 03:51 PM
Swomack's Avatar
My bike has over 50,000 + miles on it and both my rotors are fine.
I use my gears with some braking to slow down.
How about you.
Swomack
My Gallery / Click Below Link
Swomack is offline
post #3 of 34 (permalink) Old 10-03-2017, 03:52 PM
JacktheBagger's Avatar
Not uncommon for them to warp , but I would think they should be warranty items provided you still are under warranty , dont know about that where you are tho' ..
Does the front end almost get snatched out when you apply the brakes ?
My fronts warped and I replaced them with floaters
2011 Ultra
JacktheBagger is offline
post #4 of 34 (permalink) Old 10-03-2017, 04:10 PM
UT_Larry's Avatar
FYI 2016 RGS stock disks are floating disks. Make sure the dealer also checks wheel bearings & alignment. Both can cause brake drag which can cause overheating & then warping.
UT_Larry is offline
post #5 of 34 (permalink) Old 10-03-2017, 04:29 PM
08Zinc's Avatar
SLIM
Mine warped the 2 ride I took on them. Went to Bike Week and bought new wheels, pads, and rotors. No more cheap Harley parts.
How about you.
Swomack
Don't know about the OP, but I gear down as well. Had a sudden stop on a new bike as I wasn't paying enough attention to traffic trying to learn the new Rushmore stuff on the bike. Only 2nd ride and the rotors warped. Dealer was useless.
ChromeSpark likes this.
Blessings, Zinc -
08Zinc is offline
post #6 of 34 (permalink) Old 10-03-2017, 04:40 PM
bucketlisthd's Avatar
I'm light on the brakes, but my 09 rotors warped. I replaced with HD floaters. My 15 with 21K has been fine so far. I've read that you should release the brakes at a stop to avoid hot spots.
moose1 and Swomack like this.
'15 Roadglide Special
'87 FXR 100"
'79 Goldwing cafe
bucketlisthd is offline
post #7 of 34 (permalink) Old 10-03-2017, 06:11 PM
Gear down while stopping or rev match and engine brake. Either will help with reducing brake heat. You should also avoid hard stops and holding the brakes immediately after you come to a stop. As previously stated, that’s how you get hot spots and warping.
My 13’ has about 8500 on stockers and they’re smooth as all hell.
Best,
Nick
Swomack likes this.
Dvs624 is offline
post #8 of 34 (permalink) Old 10-03-2017, 06:30 PM
Nordic Berserker's Avatar
Floating rotors, 2-piece rotors do help dissipate heat better. Haven't warped mine since I put matching floating rotors with my 21" front wheel
Swomack likes this.
Nordic Berserker is offline
post #9 of 34 (permalink) Old 10-03-2017, 07:02 PM
EasternSP's Avatar
HD saves about $100 for each bike they put the cheap rotors on. It's all about the bottom line.
Ken,
- 2006 RG 107/DD6/FatBagger 200mm Rear end w/Car tire
- 2016 RGU with Car Tire
EasternSP is offline
post #10 of 34 (permalink) Old 10-03-2017, 08:32 PM
SLIM
I think 'if you take a poll and remove it from the flags swifles it will not blow as free as some of the above no nut'n wavering's', it's a crap shoot
reds4 is offline
2013 FLTRU warped front rotors dieselshadow *General Road Glide Discussions/Pictures 16 07-01-2017 08:07 AM
Warped front rotors please help Angeluz15RGS Wheels and Tires 8 03-03-2016 11:15 AM
Sick of warped stock rotors? Galfer wave rotors are here! HogPro Wheels and Tires 20 11-25-2014 07:44 PM
Warped brake rotors Kudu40 Wheels and Tires 21 09-22-2014 11:40 AM
Warped HD Rotors at 5k miles DOOFUS Wheels and Tires 6 11-05-2012 11:53 AM
