Metal valve stem - Road Glide Forums
post #1 of 7 (permalink) Old 10-26-2017, 07:21 AM Thread Starter
Metal valve stem
I've searches the forum as well as this specific section with no luck. I'd like to replace the valve stems on my enforcers with metal ones so I can add bluetooth pressure monitoring caps. Anyone know for sure the size and style stem I can use?
e.nigma is offline
post #2 of 7 (permalink) Old 10-26-2017, 07:48 AM
Mike U's Avatar
e.nigma, these are the ones I use.
Solid Billet Motorcycle Tire Valves! 82° Stem!
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #3 of 7 (permalink) Old 10-26-2017, 09:03 AM
Also check out the FOBO TPMS site, they sell a “T” valve so you do not have to remove anything to add air. They send the setup ready to fit two different sizes of stem holes. When you find out what size stems you need, I believe FOBO stems will work.
FLTRXS20 is offline
post #4 of 7 (permalink) Old 10-26-2017, 09:44 AM
NorCal's Avatar
I was also going to go with the FOBO on my Enforcer wheels. The Solid Billet Motorcycle Tire Valves! 82° Stem! Mike U posted is offset so I didn't like that one and the one FOBO sells I thought was ugly. Desertwndrr turned me on to the ones from Harley Davidson 43157-83A
NorCal is offline
post #5 of 7 (permalink) Old 10-26-2017, 01:44 PM Thread Starter
They look like the ones on my V Rod. I was told the hole is larger in the enforcer and they won't fit
e.nigma is offline
post #6 of 7 (permalink) Old 10-26-2017, 01:56 PM Thread Starter
Originally Posted by FLTRXS18 View Post
Also check out the FOBO TPMS site, they sell a T valve so you do not have to remove anything to add air. They send the setup ready to fit two different sizes of stem holes. When you find out what size stems you need, I believe FOBO stems will work.
Yeah, looks like they might.
e.nigma is offline
post #7 of 7 (permalink) Old 10-26-2017, 07:06 PM
UT_Larry's Avatar
I have the FOBO with there metal stems on my enforcer wheels. They do work well, they look decent the metal stems are required. Their website states recommend and new rubber stems are okay. Rubber stems are not had one rip apart with the FOBO installed. I can post a picture tomorrow if requested.
UT_Larry is offline
90 Degree Valve Stem Extensions jimmyray11349 *General Road Glide Discussions/Pictures 32 08-02-2015 11:56 PM
what size valve stem? 8mm or 10mm CPY84 Wheels and Tires 6 03-18-2014 06:07 PM
Angled Valve Stem (FS) JayKS Classifieds Archive (3 months old+) 6 06-25-2012 06:13 PM
Air valve stem craigp95 Wheels and Tires 7 06-23-2012 12:42 PM
Valve Stem Extension options jimmyray11349 *General Road Glide Discussions/Pictures 8 12-16-2011 01:54 PM
