200 rear tyre - Road Glide Forums
post #1 of 5 (permalink) Old 12-31-2017, 08:38 AM Thread Starter
Slimboybinz's Avatar
200 rear tyre
Does anyone know if you can fit a 200 tyre to the rear wheel of my RGS without any modifications?
has anyone done it?
If so, what make di you usee\/
SLIM
Slimboybinz is offline
post #2 of 5 (permalink) Old 12-31-2017, 09:29 AM
VikingRider's Avatar
Hi Slimboybinz; how is life in the RSA?
Regarding your question; I believe the Rushmore and 2009 and later models should fit a rear 200/50-18 without any mods. But the older models need a conversion kit. What model year is your RGS?
I have the "old" model with the old chassis/swing-arm. To give an example I would have to get the following:
- new wider swing-arm/wheel axle
- new rear custom fender
- new saddlebag support kit
- new primary kit (off-set) extended transmission main shaft and main drive gear
- new front and rear final drive pulleys and belt to fit
Cheers!
FLTRSEI2
VikingRider is offline
post #3 of 5 (permalink) Old 12-31-2017, 01:34 PM
skratch's Avatar
i would imagine since he is talking rgs, that it is a rushmore bike. nevertheless, i do have experience with the 200. i bought a set of cvo takeoffs agitators for my 2010 rgc. the tire fit fine. looked good too. ran it for a little while before i traded that bike in for my cvo.
before giving up the bike, i took the agitators off and put them on the wife's bike. i had read several articles about using a 200 on the rim that was not designed for it and what possible problems there could be, ie. tire not staying seated, etc. when i was riding it, i was always aware of what could happen, but i was willing to take the risk. when i put it on the wife's bike, i was not willing to risk her safety.
another aspect to look at. the 200 is not a multi tread tire. you'll be lucky to get 7000 miles out of it, while the stock multi tread is good for 20,000 or more.
skratch is online now
post #4 of 5 (permalink) Old 01-04-2018, 08:06 AM Thread Starter
Cheers!
Hey Viking,
Lifes just fine over here and I bet hotter than Norway!
I have a 180/65/16 on at the moment and wanted to go a size bigger without changing the wheel or anything.
Looks like my options are very limited.
Rgds
SLIM
post #5 of 5 (permalink) Old 01-04-2018, 09:13 AM
Nordic Berserker's Avatar
200 rear tire is best on a 17 rear wheel. It has been reported that some running 200s on the 18 have a tendency to get a wobble at speed. The 17" wheel is wider (6.25") and fits the 200mm tire better. The 18"s are 5.5" wide which is s little narrow for the 200mm. Stock rear rim is 16x5 & is not designed for a 200, if your sticking with stock rear rim I suggest staying at 180
Nordic Berserker is offline
wider front tyre Slimboybinz Wheels and Tires 2 10-09-2017 04:04 PM
When is a 200 X 55 X 17" tire not a 200 x 55 x17?Son of a ..... Uncle Fuzzy *General Road Glide Discussions/Pictures 5 07-17-2016 09:13 PM
Tyre To Travel with iPhone/Navigon? elbohead GPS 2 05-24-2015 09:19 AM
200 rear tire on a 09 and up? FUGLY *General Road Glide Discussions/Pictures 7 04-12-2015 06:25 PM
200/50/ZR17 Metz vs 200/55/17 Commander 2 mrnitrous Wheels and Tires 2 06-05-2013 08:14 AM
