What psi your running? - Road Glide Forums
 16Likes
post #1 of 40 (permalink) Old 04-01-2018, 04:39 PM Thread Starter
Road dawg's Avatar
Figured I would ask the question , what psi do you run in your tires? Moco says 36 in the front and 40 in the rear, tires have on them 41 psi max, so what do you guys run?
Road dawg is offline
post #2 of 40 (permalink) Old 04-01-2018, 05:25 PM
lil chief's Avatar
36 front, 40 rear. I generally ride solo. I usually run about 20psi in the air shocks.
Lil Chief
lil chief is online now
post #3 of 40 (permalink) Old 04-01-2018, 05:38 PM
38 front 40 back 19,600 miles on this set of dunlops. Got rid of those air shocks and put super shox on. Way better. 80% of miles are two up.
2011 RG ULTRA.
I RIDE. I FISH. HENCE THE THE ROD HOLDERS MOUNTED.
NOTHING LIKE DOING BOTH WHAT I ENJOY IN THE SAME DAY.
CPY84 is offline
post #4 of 40 (permalink) Old 04-01-2018, 05:57 PM Thread Starter
Road dawg's Avatar
Ok cool, I am actually trying to go 38 in front and 40 in the rear, also running Dunlops AEs.
post #5 of 40 (permalink) Old 04-01-2018, 06:12 PM
38 front/42 rear, been doing that for years and seems to work out for me. For me it works out on trips that are cooler than Florida, for when I check my air before starting out each morning.
FLTRXS20 is offline
post #6 of 40 (permalink) Old 04-01-2018, 06:28 PM
Little Wing's Avatar
why? just curious.
running dunlop oe tars & their recommendation of 36/40
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #7 of 40 (permalink) Old 04-01-2018, 06:42 PM
Cdan19's Avatar
I run 40 in both
snarley53 and SanderClaus16 like this.
Cdan19 is offline
post #8 of 40 (permalink) Old 04-01-2018, 06:47 PM
I run the max in both. Last longer...
Singlebeam is offline
post #9 of 40 (permalink) Old 04-01-2018, 06:50 PM
KansasFLTRU's Avatar
Have always run 36/40 as recommended, but 19,600 miles, CPY84?!?!?! Makes me at least want to go to 38/40!
KansasFLTRU is offline
post #10 of 40 (permalink) Old 04-01-2018, 08:39 PM Thread Starter
Road dawg's Avatar
I thinking of running slightly higher I hear that you get better wear, tires are rated at 41 psi max load, so I think when I'm two up with the tour pak on going to try it, seems like slot of you guys are getting good results from it.
What psi does everyone ride at with 2 up? CPY84 Suspensions 37 10-25-2012 05:26 AM
use of a oil pressure gauge for air psi??? bigeyed76 Equipment-RG 9 03-11-2012 11:31 PM
dummie me!!! running wrong PSI in my shocks Dmize *General Road Glide Discussions/Pictures 13 06-27-2011 08:28 PM
Tire PSI questions Frodoe *General Road Glide Discussions/Pictures 3 06-22-2011 06:03 PM
04 rear shock psi question. schnid72 *General Road Glide Discussions/Pictures 6 02-27-2011 11:26 AM
