Acceptable loss in tire pressure - Road Glide Forums
 15Likes
post #1 of 22 (permalink) Old 06-16-2018, 05:38 PM Thread Starter
Since I only get to ride a couple of time a month, the bike sits for weeks between rides. The other day I jumped on it for a short ride and noticed it handling very strange. When I got home I found that the front tire was down 10 PSI. So today I was at the dealer and asked the service department why I would be losing tire pressure on a brand new bike. I was told that a 2 to 4 PSI loss per week is normal. This seems odd to me since I have never experienced this with any of my other bikes.
Have any of you guys had a similar experience with tires deflating this quickly?
Honcho is offline
post #2 of 22 (permalink) Old 06-16-2018, 05:41 PM
Exclamation B.S.
I think that dealer is B.S.
nanook is offline
post #3 of 22 (permalink) Old 06-16-2018, 05:41 PM
Silvereagle50's Avatar
Sounds like a normal answer from someone at a dealer.
I think they teach them to give some answer so it sounds like they know what they are talking about.
2-4 #s a week is absurd. I’ve left mine sitting as long as you in winter and never lost that much.
Screamin' and madmat like this.
Mike Hutchings - SE Okla.
2016 CVO RGU
Silvereagle50 is offline
post #4 of 22 (permalink) Old 06-16-2018, 08:21 PM
twowheeladdict's Avatar
Ridiculous! I top off the tires in December and by spring I have to let out some are because the relative pressure based on atmosphere has increased.
First. You should not have ridden without checking pressure.
Second. 10 lbs in a couple weeks would have me spraying the tire with a soapy water mix to check for air bubbles escaping from the tire, valve stem, and bead.
Find a new service tech.
RGKen, BobRG15 and Garry1951 like this.
twowheeladdict is offline
post #5 of 22 (permalink) Old 06-16-2018, 08:40 PM
Little Wing's Avatar
there's really not much the dealer can do about it.
don't think you want to pay him for that anyway.
make it a habit to check them if the bike sits a week or three
RGKen likes this.
'18 FLTRX • '04 BAR HOPPER • '94 FLSTCTHE BEST BIKE ...is the one you're on!!!
Little Wing is offline
post #6 of 22 (permalink) Old 06-16-2018, 09:01 PM
The dealer is full of it. If you’re loosing 10 pounds, check your valve stem for a slow leak.
snarley53 likes this.
PeteF is offline
post #7 of 22 (permalink) Old 06-16-2018, 09:36 PM
UT_Larry's Avatar
Could a family member be messing with you? My sister was letting out 5 psi from the same tire on her exhubands truck for over a year he never was able to fix the leaking tire. She never told anyone until years after the divorce.
RGKen, madmat, Korazu and 2 others like this.
UT_Larry is offline
post #8 of 22 (permalink) Old 06-16-2018, 10:26 PM
madmat's Avatar
Checked mine yesterday, down .5 front and rear over a 4 week period. I think that is more the norm.
Sounds like more dealership propaganda.
18 RGS Bonneville Salt Pearl
madmat is offline
post #9 of 22 (permalink) Old 06-17-2018, 12:01 AM
Temperature goes down, the pressure will go down. Temperature goes up, the pressure will go up. I see you're in FL like me (a bit further south). In the Spring, the temps were all over the place. If you filled the tires on a warmer day, then a few weeks later when you checked, the temp had gone down, expect the pressure to have gone down.
After I cupped the tires on my first heavy bike (Ultra Limited), they told me to check the pressure every week or two. I do this now because tires are expensive. Prior I had been checking like I would do on my truck. It was pointed out to me that the volume of air in the truck tire is much, much greater than a motorcycle tire. Loose the same volume from the truck tire, you won't see much of a change compared to loosing the same volume from the motorcycle tire.
CantRider is offline
post #10 of 22 (permalink) Old 06-17-2018, 12:39 AM
Punishher7's Avatar
Larry, no offense but your sister sounds like a skilled terrorist. That is some next level shenanigans she was pulling. I hope he deserved it...
twowheeladdict and RoadTrip like this.
2013 RGC
Punishher7 is offline
Tire pressure gauge & tire depth gauge cobra206 Miscellaneous for Sale 1 12-04-2016 11:37 AM
Day makers: How much dust and smudge is acceptable? hometoast Lighting 6 09-09-2014 09:52 PM
Loss of oil pressure and noise mrmoto95 Engine Related 13 05-17-2013 08:47 PM
