bearing swap prob with Ultima king spoke - Road Glide Forums
post #1 of 3 (permalink) Old 08-27-2018, 07:54 PM Thread Starter
slayrr40's Avatar
Purchased a Ultima 21" front king spoke wheel, I new it came with the 1inch bearings and I was going to half to swap out with 25mm abs bearings. Prob I ran into is the 1inch bearings are thicker then my new abs bearings, so the new 25mm sit a little deeper into the hub of the wheel? I know I was going to half to make up the difference with the spacers, but this has turned into a pain in the ass, it is not just a swap out and go! Has anyone else ran into this issue with after market front wheels? I think I have the correct spacing on there now after 3 atempts but now can't get the abs light clear!!!!!
slayrr40 is offline
post #2 of 3 (permalink) Old 08-27-2018, 11:48 PM
BigBlockBobby's Avatar
You will need to measure the difference in the thickness of the bearings. That is the size of spacers you will need.
The ABS bearing needs to be right next to the sensor for it to read correctly. Don't space it away from the sensor if the bearing sits deeper into the hub. Put the spacer under the bearing to move it back into proper location.
BigBlockBobby is offline
post #3 of 3 (permalink) Old 08-30-2018, 07:47 AM Thread Starter
slayrr40's Avatar
spacer
yes i made the diff up with new spacer, putting a spacer behind the bearing isn't a good ideal unless you can machine something that has same diameter and opening as the bearing it will be behind. wish they made a kit or something? idk maybe they do? whole thing has been a pain in the ass. I guess for bikes with the 1 inch bearings these Ultima king spoke wheels will work fine but guys with the 25mm bearings its not a simple swap! thanks for info
slayrr40 is offline
Ultima high volume oil pump millerdog76! Engine Related 1 03-21-2018 03:22 PM
Rev Tech vs s&s and ultima sj01fltri *General Road Glide Discussions/Pictures 8 05-27-2013 07:19 PM
Finally cured my wind buffeting prob! Taccone Windshields 22 05-14-2013 09:48 PM
picture prob Graybone32 *General Road Glide Discussions/Pictures 1 08-16-2011 07:51 PM
Prob'ly a dumb 2011 question ... but ....... groupw *General Road Glide Discussions/Pictures 17 07-15-2010 11:12 PM
