New Tire and Rim--lose 2lbs of air per night - Road Glide Forums
 2Likes
  • 1 Post By Mike U
  • 1 Post By geo8866
post #1 of 6 (permalink) Old 09-05-2018, 04:42 PM Thread Starter
Hit a pothole and popped tire and rim was bent. Road and hazard insurance covered for new rim and tire. I am losing 2 lbs of air per night. I will take to dealer tomorrow but any thoughts on how to fix? 2017 RGS. Thanks.
US ARMY 1975-1985 IBA 69057 2017 RGS; 107; Stage I; Low Z chizeled handlebars; chopped engine guard; SE Mufflers; LED Cluster lights; Clearview Windshield; heated grips; lighted switches; Custom seat from Mean City Cycles.
2016CTRoadGlide is offline
post #2 of 6 (permalink) Old 09-05-2018, 07:57 PM
Do you have a black rubber valve stem or the metal kind? If you have the metal kind, more than likely 1 of 2 things has happened; A) whoever assembled your new wheel and tire over tightened the nut on the valve stem and split the rubber washer that is inside the wheel; or B) whoever assembled your new wheel and tire didn't tighten the nut on the valve stem enough and air is leaking past the rubber washer on the inside of the wheel.
2018 FLTRXS Wicked Red
Harley Master Tech at Hampton Roads Harley in Yorktown, VA
crazy4ink is offline
post #3 of 6 (permalink) Old 09-05-2018, 08:16 PM Thread Starter
Thanks for the insight. However, they installed a rubber valve. Do you think if they reseal the tire, it will fix the issue?
post #4 of 6 (permalink) Old 09-05-2018, 08:19 PM
Yes I do. You can ask them to put bead sealer around the beads also. Also, the center core could be loose.
post #5 of 6 (permalink) Old 09-06-2018, 12:08 PM
Mike U's Avatar
Did you check and make sure that the Schraeder Valve inside the Tire Valve is tight?
Mike U.
geo8866 likes this.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #6 of 6 (permalink) Old 09-06-2018, 12:53 PM
geo8866's Avatar
Mike U.
The simplest answer is usually the correct answer. ^^ I'd check that first.
Mike U likes this.
geo8866 is offline
WTB: 2015+ Road Glide front rim or rim and tire. Mooseinthetub Wanted! (Buy or Trade) 5 07-01-2016 11:00 PM
Rim, tire, forks, cow bells, and rear fender Drag 2013 Parts for Sale 16 03-01-2015 03:03 PM
lose the wheat lose the weight by Davis pasa Healthy Living 17 08-14-2013 03:00 AM
2013 road/street glide front tire and rim Jlacroix2001 Parts for Sale 1 08-12-2013 08:20 PM
Front rim and tire 13 rgc Jlacroix2001 Parts for Sale 0 04-09-2013 03:46 PM
