180/55/18 Rear wheel wobble - Road Glide Forums
post #1 of 9 (permalink) Old 12-07-2018, 01:23 PM Thread Starter
I have a 2012 RGU that I upgraded the wheels to Agitators. When I got the rear wheel it had a Goldwing tire on it. At 60 mph and above I got a bad wobble in the rear. Took it to the HD dealer in Miami where I had ridden the bike to. They thought it was the tire itself to which we changed to a HD tire for the wheels. That seemed to have fixed it initially until I took the bike to 90 mph. At that point the wobble came back. At a loss now as to what could be the problem.
pryda is offline
post #2 of 9 (permalink) Old 12-07-2018, 01:43 PM
Glide08's Avatar
Is it a wobble or a out of balance situation.. I changed wheels on my 08 and went to 18" with lower profile tires they vibrated a lot at speed was a balance issue. When I did that change I lost a lot of the smooth ride the meatier tires gave, they absorb a lot of small road imperfections that you feel with these lo profile tires. I was actually thinking of putting a 17" on my front of my 2017 and a 80 series tire just to soften the ride.
Glide08 is offline
post #3 of 9 (permalink) Old 12-07-2018, 01:56 PM
08Zinc's Avatar
I had that set-up on my 2011 with zero issues, so I am wondering if the wheel is bent or damaged by the previous owner.
Blessings, Zinc -
08Zinc is offline
post #4 of 9 (permalink) Old 12-07-2018, 03:02 PM Thread Starter
This was my fear. I bought the wheel off Ebay from a dishonest broker. I plan on taking the bike back to Harley to verify if the wheel is damaged. I would have thought that when they put the tire on the wheel and balanced it they would've seen a wheel error.
pryda is offline
post #5 of 9 (permalink) Old 12-07-2018, 03:36 PM
Glide08's Avatar
My thoughts exactly
Glide08 is offline
post #6 of 9 (permalink) Old 12-07-2018, 03:55 PM
Mike U's Avatar
pryda, when you first had the wheel installed were the wheel bearings checked?
Just a thought.
Hope you find the problem.
Keep us posted.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is offline
post #7 of 9 (permalink) Old 12-07-2018, 07:29 PM Thread Starter
Yes the bearing were part of the troubleshooting in Miami. The mechanic said they were good.
pryda is offline
post #8 of 9 (permalink) Old 12-08-2018, 09:48 AM
BH#103's Avatar
I think you may have found the answer to your problem with that ^ statement. Otherwise, unless it can be proven that the bearings are new I personally would have new bearings installed in any used wheel I were to buy. Another thing to check is the tire itself, even though it is new there is the possibility that something might be amiss with it. Not likely, but possible. I had a brand new Avon Cobra that was a dud. See if the dealer can troubleshoot the rim separately from the wheel assembly. Spin the rim on the balancer to check for runouts and then the compete wheel assembly and check the same if the rim check didn't produce any negative results. Just my .02. Good luck!
"SLIVER"
BH#103 is online now
post #9 of 9 (permalink) Old 04-22-2019, 11:37 AM
I'm having this same exact problem putting these wheels on my 2015 RG Special. I put a 1" lowering kit on and it helped but didn't get rid of the problem. Is there anything you found to help yet?
JTKIMBREL is offline
American Elite 180/55/18 - soon! Mudslide Wheels and Tires 7 11-18-2015 06:02 PM
OK, 180/55/18 rear tire choices??? ChromeYellow67 Wheels and Tires 9 09-23-2014 08:16 PM
180/55 18 on the front & rear FLTR2008Trike Wheels and Tires 13 04-12-2014 05:01 PM
Bridgestone Excedra 180/55-18 twrguy Wheels and Tires 11 10-05-2013 04:59 PM
180/55/18 Flips tear Wheels and Tires 10 09-14-2013 10:51 AM
