Looking for a Chrome Solid 16x3 rear wheel - Road Glide Forums
  • 1 Post By crazy4ink
post #1 of 5 (permalink) Old 12-20-2018, 03:23 PM Thread Starter
Mike U's Avatar
I've been scouring the good old inter webs and can't find an answer so I figured I'd ask the knowledgeable Brethren of Our Great Forum.
I would like to put a Solid Rear Wheel on my 2012 Custom and wanted to know if anyone knows of a brand or Harley OEM that will fit?
Thanks, in advance, to All that reply.
Mike U.
USMC 1975-1977
Semper Fi!
Nothing else matters!
Mike U is online now
post #2 of 5 (permalink) Old 12-20-2018, 03:50 PM
Are you going to be using a 25mm axle? Are you opposed to using a Fat Boy wheel? I’ve seen a number of them on eBay and I had gotten a set for ‘77 FL. Are you still wanting to use Cush drive? Chain drive?
2018 FLTRXS Wicked Red
Harley Master Tech at Hampton Roads Harley in Yorktown, VA
crazy4ink is offline
post #3 of 5 (permalink) Old 12-20-2018, 04:00 PM Thread Starter
Mike U's Avatar
I have the stock axle from my 2012 Custom on there now Bro.
I wanted to keep the Cush Drive and Belt but not opposed to changing if it's necessary.
I wanted to go with the Fatboy Solid Rear Wheel in chrome but didn't know what I would have to do to make it work.
Thanks for your assistance.
Mike U.
USMC 1975-1977
Semper Fi!
post #4 of 5 (permalink) Old 12-20-2018, 04:40 PM
I wanted to go with the Fatboy Solid Rear Wheel in chrome but didn't know what I would have to do o make it work.
Mike U.
To make the wheel work, the easiest way would be to get (2) 25mm bearings and use the center spacer from your existing wheel, since it’s the same width as your current wheel. That should allow you to use the wheel spacers that you already have.
As for the Cush drive; I can’t remember what year had the bolt on Cush drive cup versus the molded in style. If your has the bolt on style cup, it will have the same bolt pattern as the sprocket that would have bee on the Fat Boy wheel so you should just have to bolt the Cush drive cup onto the Fat Boy wheel.
Mike U likes this.
post #5 of 5 (permalink) Old 12-20-2018, 04:44 PM Thread Starter
Mike U's Avatar
To make the wheel work, the easiest way would be to get (2) 25mm bearings and use the center spacer from your existing wheel, since itís the same width as your current wheel. That should allow you to use the wheel spacers that you already have.
As for the Cush drive; I canít remember what year had the bolt on Cush drive cup versus the molded in style. If your has the bolt on style cup, it will have the same bolt pattern as the sprocket that would have bee on the Fat Boy wheel so you should just have to bolt the Cush drive cup onto the Fat Boy wheel.
Thanks, once again, Bro for all the information.
I'm probably going to give that a try and see how it goes.
Mike U.
USMC 1975-1977
Semper Fi!
Solid rear wheel for bagger Manfire1987 Wheels and Tires 16 03-10-2016 10:37 PM
Solid wheel 1rstfltr99 Wanted! (Buy or Trade) 5 04-05-2013 11:15 AM
Looking for a solid 17" Chrome Wheel SIG556 Wheels and Tires 14 11-17-2012 08:10 AM
