18-19 RGS Wheels - Road Glide Forums
post #1 of 3 (permalink) Old 01-07-2019, 10:04 AM Thread Starter
craigffb's Avatar
18-19 RGS Wheels
Next time someone has a tire changed on a 18 or 19 RGS can you ask the place swapping out the tire to check and see if the wheel has a notch for a tire pressure sensor.
Thanks
craigffb is online now
post #2 of 3 (permalink) Old 04-25-2019, 07:54 AM
Do you really need a notch? I just put them on my HD Agitator wheels and I don't believe they have a notch - but can't say for sure.
Dagwood08 is offline
post #3 of 3 (permalink) Old 04-25-2019, 08:40 AM Thread Starter
craigffb's Avatar
I'm pretty sure the notch isn't much of a factor at this point. The valve stem size however is. Your rim has a 8.3mm valve stem hole, the RGS OE rim has a 11.3mm hole. The CVO TPMS valve stems are 8.3mm. There is a gasket that FOBO uses to make a 8.3mm steam fit a 11.3mm hole but I can't find any info on anyone who is using it. Luckily I won't need tires for a while so maybe by the time I do some one else will have been the guinea pig.
2014 Enforcer Wheels to Replace 2012 Wheels Jthompson1995 Wheels and Tires 3 12-23-2018 06:21 PM
Wheels to the Wall Pledge Ride JohnnyIce Organize Rides Here 0 03-14-2016 10:05 AM
contrast chrome Agitator wheels and parts Wheelie Sold 8 02-01-2013 02:42 PM
Wheels, wheels, wheels, chrome, black, both, whatever post em up! zuppy51 Wheels and Tires 33 10-24-2012 08:46 AM
18" HD Blade Wheels TheDawg Classifieds Archive (3 months old+) 7 08-02-2011 12:50 AM
