Harley tire pressure monitors - Road Glide Forums
 2Likes
  • 1 Post By ia15rgs
  • 1 Post By Dagwood08
post #1 of 4 (permalink) Old 04-24-2019, 09:44 AM Thread Starter
ia15rgs's Avatar
Did this last night at work. You can put the cvo tire pressure valve stems in an ultra. Go into digital tech and assign them/setup. Blah blah. You have to go under the radio flash and turn on the tire pressure option. Works just fine. Have not tried it on a special rear rim. But I would guess it should work. You just have to tell the guys from now on when you get s tire change that they are in there. The tire machine may reach the dodads cuz we are putting them on the wrong rim. H-D specifies for center valve stem mounts only. That way they are sure to clear the sensor.
twowheeladdict likes this.
ia15rgs is offline
post #2 of 4 (permalink) Old 04-24-2019, 12:03 PM
skratch's Avatar
i was gonna ask you about that yesterday as well, but didn't want to hit you with too much at one time, and it isn't like i was gonna buy the sensors right then anyway. figured that could wait....
so, do you guys keep those in stock? (if you need a test mule..... ;D)
btw, location still shows as orlando....
skratch is offline
post #3 of 4 (permalink) Old 04-24-2019, 12:11 PM
craigffb's Avatar
What rim did you put it on? The RGS rims valve stem hole is 11.3 mm and the CVO rim valve stem is 8.3 mm.
craigffb is offline
post #4 of 4 (permalink) Old 04-25-2019, 05:20 AM
I had this done on my new 2019 RGU before I picked it up. I also had HD Agitator wheels added at the same time. It's a simple thing to do, contrary to some parts people insisting the CVO's have some magical extras to allow the TPMS to work and non-CVO's can't be enabled.
RGKen likes this.
Dagwood08 is offline
Acceptable loss in tire pressure Honcho Wheels and Tires 21 06-21-2018 06:20 AM
Check Tire Pressure MakeARunMike Wheels and Tires 11 10-20-2012 06:53 PM
Lost tire pressure...? Johnzz1420 Wheels and Tires 7 07-19-2012 08:22 AM
Check your tire pressure!!!! Neano62 Safety Area 5 06-09-2012 09:43 PM
Tire pressure gauge and air filler flhr95 *General Road Glide Discussions/Pictures 13 02-27-2012 07:49 PM
