Factory wheel balancing!? - Road Glide Forums
 2Likes
  • 1 Post By BubbaBeef
  • 1 Post By RGKen
post #1 of 5 (permalink) Old 07-15-2019, 03:50 PM Thread Starter
-VINSON-'s Avatar
This is a completely stock wheel and tire. Never been touched or dismounted. this is how it came from the factory.
Is this normal for a wheel to be this out of balance from the dealer??
Personally, I want to take it back to the dealer and ask them for a new wheel. for $28K you would think you could get a balanced wheel lol
Let me know your thoughts and what my options may be.
-VINSON- is offline
post #2 of 5 (permalink) Old 07-15-2019, 04:04 PM
RGKen's Avatar
I believe 3.5oz is the maximum for any motorcycle tire. They should have broken the tire loose and turned it 180 degrees on the wheel and tried again. If it is still too far out then they should have put another tire on. If it is the wheel they should have scrapped the wheel.
2018 FLTRXS
RGKen is offline
post #3 of 5 (permalink) Old 07-15-2019, 06:49 PM
Hopalong48's Avatar
How much weight is on it?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Hopalong48 is online now
post #4 of 5 (permalink) Old 07-15-2019, 07:30 PM
BubbaBeef's Avatar
Location: Northern Illinois, where the suburbs end and the corn fields begin
I see 80 grams = 2.9 ish oz.
I'd take it to your dealer, have them spin the tire 180 degrees and try to balance again. Or go with Dayna Beads.
RGKen likes this.
Panic, chaos, disorder, my work is done here.
BubbaBeef is offline
post #5 of 5 (permalink) Old 07-15-2019, 07:53 PM
RGKen's Avatar
I looked at the pic closer and it looks like you have 80 grams. 3.5oz. is 99.2grams so it is actually within spec but I would do like BubbaBeef said and have the dealer rotate the tire 180 to see if it improves. You can use Dyna beads but that tire still needs to find a better spot on the rim to get it closer. Once that is done I would use Ride-On myself because it is a sealer as well as a balancer.
JGray likes this.
2018 FLTRXS
RGKen is offline
