Does anyone know which pins on the 35-pin connector are the factory rear speaker outputs on a FLTRU? I'm upgrading my audio and have the fronts pretty well wrapped up, just need to identify the rear outputs to run to the amp. Anyone got that info?
Thanks again Erod. Looks like I need to make another wire/pin set to run from the 35-pin connector to the amp. If I leave the original pin set intact, I can run mating pin from the amp back to the harness. Just need to sort out part numbers for the pins. I'll start digging the forum and see if anyone has that info.
Thanks again!
Cheers,
G
Related Threads
Road Glide
1.4M posts
49.3K members
Since 2009
