Road Glide Forums (https://www.roadglide.org/forumindex.php)
-   Equipment-RG (https://www.roadglide.org/4-equipment-rg/)
-   -   What type of Jack/Lift do you use? (https://www.roadglide.org/4-equipment-rg/241617-what-type-jack-lift-do-you-use.html)
BDMastiff 09-15-2015 07:32 PM
I'm looking for a new jack. Not sure if I want a jack or lift table. Primary use will be general maintenance, service, and maybe cleaning. I'm a novice mechanic but always learning to do more. Help me!!!!
r_einan 09-15-2015 07:43 PM
1 Attachment(s)
I've been using an inexpensive harbor freight bike jack for years. Works good for most things, doesn't make things as easy as a table would.
Bandit 7 09-15-2015 07:54 PM
148 Attachment(s)
I've had a aluminum Craftsman jack for 10 years now with no problems. Recently got a harbor freight table lift I like it not much use yet to give a good review. I will say you have to put a better wheel chalk on this lift. What it comes with is crap.
lil chief 09-15-2015 08:13 PM
Been using a Harbor Freight table lift for a few years now. As stated, change out the wheel chock. I welded together some frames that are removable from the table and topped them with plywood so I can ride my bikes right up onto the lift
Big_gary 09-15-2015 08:40 PM
Been using a $100 Larin for 15 year without fail. Does everything I needed it to do. A buddy just bought a Pitbull lift. Its a nice jack and a much stouter jack than mine, but also cost a good bit more. In the end, they both do the same thing.
rlaf75 09-15-2015 10:50 PM
I used the red craftsman jack for several years without any problems. I did however buy the harbor freight lift table a couple of years ago and that's been great. I use that for everything. Comes in handy for a work bench when the bike isn't on it
SurlyBoy 09-15-2015 11:06 PM
I like my Larin lift for general maintenance and service. Helps to get the wheels off the ground or even just to support a bike upright. For building or major surgery I use my HF table. You can get the work right up in front of you and use the top as a work surface for tools and parts.
Jayray 09-15-2015 11:48 PM
Harbor Freight lift table and a wheel chock. I was out the door UNDER $300.
JacktheBagger 09-16-2015 02:07 AM
Torin Big Red jack , werks great , shop I built for the bike isn't really big enuff for a table though I would like one ..
May check into the HF for grits and shiggles
JtB
BobRG15 09-16-2015 06:41 AM
Check out Lifts-and-Stands.com They are pricey but you be the judge
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
