Road Glide Forums (https://www.roadglide.org/forumindex.php)
-   Do-IT-Yourself (https://www.roadglide.org/29-do-yourself/)
-   -   Does this look right? (https://www.roadglide.org/29-do-yourself/372209-does-look-right.html)
Headrope 04-21-2019 02:32 PM
3 Attachment(s)
Wife bought me a pretty part for our 2010 ’Glide. Installation was simple - too easy, really - so Im looking for reassurance:
Harley’s bar and shield linkage will end up somewhat at an angle once installed, right? And that angle won’t screw anything up over time?
BH#103 04-21-2019 02:45 PM
The linkage should be vertical with both Heim joints not stressed to one side or the other. A Heim joint is the bearing type joints at the end of the linkage.
RealCowboyMD 04-21-2019 02:47 PM
Make sure it wiggles(rotates) on the heim joints and you are good.
skratch 04-21-2019 02:50 PM
i just went through this myself. i replaced the stock linkage with the linkage off my old cvo. without using spacers, there is no way to make the linkage perfectly parallel. i rode for about 50 miles yesterday, and shifting was great, there was no binding, and i had no issues.
RFG7680 04-21-2019 04:01 PM
Mine is a bit off too. Like Skratch said. Without spacers. Just get it as best ya can. Mine works flawlessly.
Headrope 04-21-2019 08:23 PM
It rotates freely (tilts forward/back) on the joints. Thanks, sir.
Headrope 04-21-2019 08:24 PM
Agreed: There is no way other than spacers to make it parallel. Looks like Iím good. Thanks!
Headrope 04-21-2019 08:26 PM
Appreciate it. This thing was too easy to install. Usually for me that means trouble.
Iím gonna stamp this one as done. Thanks for the reply.
30glock 04-22-2019 06:44 AM
They all do that :grin:
Thermodyne 04-22-2019 08:53 AM
Na, that's all out of kilter.
It wont mount to the inside of the front lever?
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
