1 - 16 of 16 Posts
My uncle has an 02 road glide. It occasionally has a problem of not starting. Like today we went for a ride.. Started fine. We stopped at a gas station to fill up. We were getting ready to leave when it decided not to start. Ignition and kill switch are on but when he hits the button to start it, it doesn't do anything.. But if he rolls it backward or forward a few feet and locks up the front brake and gives the bike a hard jerk, it starts. Any ideas? Loose wire? Loose connector? Inside the controls on the handle bars? Behind the fairing? As I said above though, it only does this once in a while
Maybe a sticking start relay?
Im assuming when you say "doesn't do anything" that it's not cranking over? If so carry a small hammer or a decent sized screwdriver with you guys. Next time it doesn't start gently tap the starter while hitting the start button. Try this before you roll the bike. If it starts while you tap the starter then your starter needed to be replaced or rebuilt. If it still doesn't start then start checking for power at the starter wires.
Sounds about right.
It happens once in awhile on my 08 and all I need to do is turn the ignition off and then back on and the bike starts fine. I don't know what causes the ignition to do this but it does.
Discussion Starter · #11 ·
To answer everyone's questions:
By "doesn't do anything", it doesn't turn over, doesn't click.. It doesn't do anything
The white on the start button is less than half visible, and not sure of the miles.
Yes it is in Neutral
And he has tried turning the ignition off and back on, but still doesn't work. Only thing that works so far is what I said before.. Roll the bike forward or backward and squeeze the front brake hard to give the bike a hard jerk.. Then it fires right up
If the fuse blocks are tight and the management systems (relay looking sht) is not or wires shaved, get ^^^ a drift place on starter, no the end and slam with 2x4, what I'd do, then hit start, as said ^^^^
You need to see if the starter is getting power. Get a test light, hook it to a known good ground then probe the starter wires while hitting the start button. The big wire will or should have power constantly with the ignition on and the small wire should have power when you hit the start button. Find out if it has or doesn't have power.
1 - 16 of 16 Posts
