1 - 2 of 2 Posts
The cruise on my 04 road glide doesn't work.many symptoms: when I start up the bike,with cruise switch off, the cruise icon blinks green then red 4 or 5 times then goes out.other times i turn the cruise switch on and can't engage from handle bar switch,and then sometimes i can get it engaged and it works for a minute or so, then won't hold speed.any ideas. thanks:confused:
Check your front brake lever and make sure it does not have the brake light switch activated, mine did that , switch was loose in the housing letting it move.
1 - 2 of 2 Posts
