1 - 3 of 3 Posts
Priority/DTC/Fault condition
HFSM= Hand Free Security Module
TSM= Turn Signal Module
P0605-ECM Flash memory error
P0603-ECM EEPROM memory error
U1300-ECM serial data low
U1301-ECM serial data high
U1097-Loss of speedometer serial data to ECM
U1064-Loss of TSM/FSFM serial data to ECM
P1001-System relay coil open/low
P1002-System relay coil high/shorted
P1003-System relay contacts open
P1004-System relay contacts closed
P1009-Incorrect password
P1010-Missing password
P06415-V+Vref 1 out of range
P06515-V+Vref 2 out of range
P0373-CKP sensor intermittent
P0107-Map sensor open/low
P0108-Map sensor high
P0374-CKP sensor synch error
P1511-Throttle actuator control power management failure of throttle control actuator
P1600-EFI module processor internal error
P1270-TGS validation error
P2107-EFI module processor internal fault
P2101-Throttle actuator control motor circuit range/performance error
P2122 -TGS1 low/open
P2123-TGS1 high
P2127-TGS2 low/open
P2128-TGS2 high
P2138-TGS correlation error ( Twist Grip Sensor )
P0120-TPS1 range error
P0122-TPS1 low
P0123-TPS2 high/open
P0220-TPS2 range error
P0222-TPS2 low
P0223-TPS2 high/open
P2135-TPS correlation error
P2119-EFI motor throttle body range performance
P2100-EFI motor circuit low
P2101-EFI motor circuit range performance (Actuation Error)
P2102-EFI motor circuit low
P2103-EFI motor circuit high
P2176-EFI closed position not learned
P1514-Air flow fault
P2105-EFI forced engine shutdown
P1501-Jiffy stand sensor low
P1502-Jiffy stand sensor high
P0572-Brake switch low
P0117-ET sensor low
P0118-ET sensor high
P01121-AT voltage low
P01131-AT voltage open/high
P1351-Front ignition coil driver open/low
P1352-Front ignition coil driver high/shorted
P1354-Rear ignition coil driver open/low
P1355-Rear ignition coil driver high/shorted
P1357-Front cylinder combustion intermittent
P1358-Rear cylinder combustion intermittent
P0261-Front injector open/low
P0262-Front injector high
P0263-Rear injector open/low
P0264-Rear injector high
P0562-Battery voltage low
P0563-Battery voltage high
P0501-VSS sensor low
P0502-VSS sensor high/open
P1356-Rear cylinder no combustion
P1353-Front cylinder no combustion
P0444-Purge solenoid open/low
P0445-Purge solenoid high
P1475-Exhaust actuation position error
P1477-Exhaust actuator open/low
P1478-Exhaust actuator high/shorted
P0131-Front oxygen sensor low
P0132-Front oxygen sensor high
P0134-Front oxygen sensor inactive
P0151-Rear oxygen sensor low
P0152-Rear oxygen sensor high
P0154-rear oxygen sensor inactive
P1510-EFI limited performance mode
P1511-EFI power management mode
P1512-EFI forced idle mode
P0577-Cruise control input high
U1300-Serial data low
U1301-Serial data high
U1016-Loss of ECM serial data
U1255-Serial data error
B1142-Smart security system internal fault
B1135-Accelerometer failed
B1136-Accelerometer tip test error (HFSM)
B1151-Bank angle sensor short to ground
B1152-Bank angle sensor short to battery
B1153-Bank angle sensor high
B1154-Clutch switch input short to ground
B1155-Neutral switch input short to battery
B1134-Starter output high
B1121-Left turn output fault (TSM) or left turn output open (HFSM)
B1122-Right turn output fault (TSM) or right turn output open (HFSM)
B1123-Left turn output short to ground (HFSM)
B1124-Right turn output short to ground (HFSM)
B1125-Left turn output short to battery (HFSM)
B1126-Right turn output short to battery (HFSM)
B1143-Security antenna short to ground (HFSM)
B1144-Security antenna short to battery (HFSM)
B1145-Security antenna open (HFSM)
B0563-Battery voltage high
B1131-Alarm output low (HFSM)
B1132-Alarm output high (HFSM)
B1141-Ignition switch low/open (TSM/HFSM)
The following codes are from a 08 diagnostics manual for bikes with ABS
C0562-Device voltage low
C0563-System voltage high
C1014-ECU internal fault
C1017-Pump motor power circuit open fault
C1018-Pump motor ground high resistance fault
C1021-Front wheel speed sensor equals 0
C1027-Rear wheel speed sensor equals 0
C1025-Front wheel speed signal intermittent
C1027-Rear wheel speed signal intermittent
C1032-Front wheel speed sensor circuit open/shorted
C1034-Rear wheel speed sensor circuit open /shorted
C1042-pump motor open
C1043-Pump motor stalled
C1055-ECU internal fault
C1056-ECU internal fault
C1057-ECU internal fault
C1061-ECU internal fault
C1062-ECU internal fault
C1065-ECU internal fault
C1066-ECU internal fault
C1118-ECU internal fault
C1121-ECU internal fault
C1094-Front brake switch always on
C1095-Front brake switch open
C1151-Front wheel release too long
C1153-Rear wheel release too long
C1158-Calibration programming required
C1206-Wheel speed sensor frequency out of range
C1208-Wheel speed sensor frequency out of range
C1212-Front or rear brake not applied with decel
C1214-Rear brake switch always on
C1216-Rear brake switch open
TSSM -Code -Unknown
Is there a way to retrieve an unknown security code for a TSSM ? I`m told you can`t retrieve it, rendering the unit useless. Is that true ? Trying to install a used TSSM on a bike ! HELP
Make sure the battery does not run down when doing this procedure, it is recommended that the battery is hooked up to a battery charger .
After installing the TSM/TSSM you should ;
1- set run/off switch to run
2- turn ignition switch on , make sure check engine & security lights turn on and then turn off. The TSM/TSSM will enable the starter relay.
3- Attempt a normal start one time . The engine should start and stall & the check engine light turns on & stays on. The password has NOT been learned & the ECM/ICM sets DTC code P1009.
4- wait ten seconds, the security light will light and stay on. The ECM/ICM enters the password learning mode for ten minutes. DO NOT cycle ignition switch or interrupt vehicle power or password learn will be unsuccessful.
5- wait until security light turns off. this will take ten minutes.
6- QUICKLY (within two seconds) turn the ignition switch OFF-ON. The ECM/ICM must not be allowed to shutdown.
7- wait until the security light turns OFF. This will take ten minutes.
8- QUICKLY (within two seconds) turn ignition OFF-ON. The ECM/ICM must not be allowed to shutdown.
9- wait until the security light turns OFF. This will take ten minutes.
10- QUICKLY (within two seconds) turn the ignition OFF-ON. The ECM/ICM must not be allowed to shutdown.
11- turn the ignition OFF. WAIT for 15 SECONDS before turning ignition ON. Turn the ignition ON and start the engine to confirm successful password learn procedure. Then CLEAR the DTC code.
1 - 3 of 3 Posts
