No Longer For Sale................
Have a 2009 Headpipe (Catless) forsale. Bought here from forum member.
Asking $100.00 plus shipping.
No Longer for Sale...........................
that one is using the 18 mm sensors near the heads right ??
JtB
Cant recall exact size right off but if used on 11,12 or 13 model the or relocation kit is required not expencesive. just adapts down to smaller bung.
For those wanting to use 09 headpipe on 10-13 models here is what you need with out a Tuner.
O2 Sensor Relocation Kit Part # 22 KnightRider.com $31.99
FL-Vied -10 Part # 104 KnightRider.com $119.99
Do you have any better pictures? So these are the stock head pipes? For duals?
Only Pic I have at the moment. Yes, stock Headpipe & Heat shields& crossover pipe off 2009model. 09 headpipes have no cat. converter. Have larger bungs for o2 sensor, wideband o2 senseor. Has no smaller bung for the smaller sensor. But there is adator kit sold so they will work.
A factory harley catless headpipe that doesn't have to be cut open & welded back.
No mufflers included.
