I have a set of the Taylor plug wires. When I installed the cams my dyno guy said to take them off cause theycaused some kind of error code. Does anybody no what this code is and how it affects the bike. 2013 Rg ultra with 57 h cams
These bikes use the stock ignition system and stock plugs to sense predetonation. Changing the characteristics of the ignition system throws things out of whack. Go back to stock and it will run better.
We did a battery of dyno testing with wires many years ago.
Results were...................................nothing to be found.
OEM wires are just fine.
Scott
I've never changes my cams but was thinking of replacing my plug wires with the screamin eagle 10mm phat wires. Any issues there?
No advantage in the the 10mm wires, I used both stock and 10mm wires and IMO you should save your cash for something else.
