If i go to a 107 and ported heads with Drago's 2.5 kit and 580 cams how much difference will i have if i switch to true duals instead a my 2-1 V&H pro pipe. Will it make that much of a difference?? Thanks in advance Dan
For what it's worth. I have 2-1 vh high output pro pipe. My stage 4 dyno'ed 121 hp. A friend with true duels stage 4 dyno'ed 114 hp.
I replied back to your PM. On going with duals
Now with our New H Pipe you can have the best of both worlds!
Looks like duals sound like duals and performance more like a 2:1
No pinch points under trans never had them never will!
This pipe is balanced front and rear cylinder with our matching new baffle design only from Dragos.:D
The left and ride sound mufflers will flow almost the same 95%
Specs .. On Hpipe
Diverter tabs
Spiral cut header inside
Ceramic coated inside and out
16 gauge steel
and Heat shields !!!
Check out Youtube Vide down below.
https://www.youtube.com/watch?v=jhAJE-QoCoM
Yes there is give me call Thursday we can go over all your needs and discounts
QUOTE=pipe3214;2311314]Wow those sound awesome. I'll look at your site for cost. Is there a brake for a 107 2.5 kit and pipes? Thank you again
Sent from Motorcycle.com Free App[/QUOTE]
