1 - 2 of 2 Posts
I am looking for a tuner for my new engine build. It is a 116" JIMS with 10:1 compression, 585G cams, ported heads, RB Racing LSR 2:1 exhaust. I have read about adding the O2 sensors in on the 05 and 06 touring bikes and using a PowerVision but do not know how that would be set up or if really possible.
I used a PCV with Autotune on an 06, worked great for 93k. No reason why you can't use a power vision and the autotune. I would probably goto S&S for a Base map on one of their 117's or if you buy the PV etc from Fuel Moto, I'm sure Jamie has a map that will be close from a 117.
1 - 2 of 2 Posts
