21 - 28 of 28 Posts
I've heard this very same thing. I've considered these bars myself, and your writeup makes it a bit more likely that I will go this way. Being two inches shorter than you I'll go with the 12" bars.
Thanks for the writeup!
I’m 6’ too. So post some pics when you do this mod!
Congrats, looks killer bro!...Love me some new bars!!
Or, where have you been all my life, 14" apes?
I'm getting old. I have minor stenosis in a few of my cervical vertebrae, which - if I don't keep my posture just so - causes tingling and numbness in my left arm. I'm broken down too. I had a microdiscectomy for my L1/S1 vertebrae back in April. I also had a nasty bunch compression fractures in my left wrist from a bike wreck a few years ago. It healed, but the bones knitted back together just a bit crooked, so my left hand sort of sits at a weird angle at the wrist.
I'd pushed the stock Ultra bars forward a bit, but the pullback on them was just too much. I've ridden like that for just about 4 years, but my last ride to Toledo and back left me with numb hands and a sore back from slumping over.
I saw a thread here about the KST Vanguard series bars, loved the adjustability of the pullback, and figured, "what the hell?" Ordered them from Dennis Kirk, waited a week, and here we are. Also decided to install Harley heated grips at the same time.
The video from KST leaves some stuff out and oversimplifies the installation. The written instructions are pretty poor (but still better than Harley's instructions for the grips. Having a shop manual helps.
Getting the old bars off is simple. The KST video forgets to tell you to remove the trigger button from the left grip. Small screwdriver, slide it outboard and off. Definitely put a towel over the tank. I'd already removed the pin from the bar clamp, a hammer and punch snap the pins off the clutch and brake clamps.
Have a seat at the kitchen table, pull the wires out of the old bars. Take the lower mount for the new bars, make sure it's oriented per the instructions, and put the two side pieces into the lower clamps. Pound them flush with the bottom with a rubber or leather mallet. Snug but don't tighten the pinch bolts.
Take the woven "finger trap", thread it through the new bars, stick the plugs in the top end (I used blue painter's tape on one plug that wouldn't fit), and run the new wires. Piece of cake.
Get the new bars on the bike, make sure the hydraulic lines are behind the bars and that the wiring can be run behind the nacelle, and clamp the bars down. Get on the bike, adjust everything where you want it, whip out your torque wrench, and tighten everything down.
The wiring is a piece of cake. The hydraulic lines......No so. KST says you can use the stock lines, and you can, but...I don't like how tight they are. At full lock, you'll pull the line loom on the right side (the plastic piece that all the hydraulic lines run through) out of its holder. These bars really need another inch on each of the lines, 2" would be even better.
Anyhoo, I buttoned everything up and went for a ride. Total time was 4 hours, and I could do it again in 2 hours.
Holy mother of god.....I can't believe how much more comfortable my bike is. I rode for 90 minutes and no numbness or tingling in my hands or arms. My back stayed straight without having to think about it. These things are the shiznit.
Great looking bars. I like how you get to set your pull back the way you like. How secure are those clamps at the bottom ?
He’s talking about the button on top that changes the odometer/tripometer I believe
A question on running the wiring. I can see the cables coming out of the end of the side pieces. Does the wires run through the cross bar? If not I would assume (I know) the cables are routed out the bottom of the side pieces and behind the cross bar. If this is the case what were you required to do to keep the cables clear so they were not damaged over time?
TIA
They look great but for some reason they look like 16's. Im running 14's and they dont look that tall to me... Great write up. Im glad you really like them.
21 - 28 of 28 Posts
