1 - 4 of 4 Posts
Installed:
Arc Audio XDI600.4
Focal 154KRC's
Hybrid Audio 157-2 5x7's in the lids
New inner bracket to mount the amp...
OEM on the left... NEW on the right with amp mounted
Now... this entire system came out of my 14SGS....
I got it done in 5-6 hours and cannot believe the difference in sound from the RGS over the SGS. The bass response is HUGE on the the RGS faring. All tuning was untouched.. just a straight swap with a flash from HD as I told them to do it with 19.1 software update.
Discussion Starter · #3 ·
Stock bracket will not work for the XDI 600.4. Got the new bracket from Soundz Customz. Fit perfect, just needed to drill/tap new 10×32 holes to mount it.
Entire system is plug and play... level IV system fom Soundz Customz... comes with everything you need.. even tuned specific for your sled.
On my setup... I only use to two front channels from the head unit and split it for the rears. No fade control... and don't need it
Hey Spazz,
Did you have any problems mounting that bracket and getting a gap at the stereo to inner fairing? I'm trying to install my Level 3 system and I have a 1/4" gap around the stereo and the top ears are stressing the plastic a bit. I'm just curious if yours worked or if you had to mod it a bit for a good fit.
Peter
1 - 4 of 4 Posts
