1 - 20 of 25 Posts
So a week ago I leave on a little ride ~ at less than 16k I have a knock in the bottom end ~ check the compensator ~ chain ~ all good here. Take it to the boutique and the bottom end is the culprit ~ crank pin or rod bearings ~ I can tell you reassambly will include Timken Bearing conversion, Lefty Bearing, Crank Trued, plugged, welded.... Downside is I won't be riding for a month or so ~ upside is that a more dependable platform when complete.... The bike is less than six months old and I understand these things happen just a little frustrating.
I assume the work is being done under warranty with you just paying for the extra parts?
Thanks Qkshift ~ I ride all year ~ fortunately ~ thinkin about a month or so to get it back. Going to make sure that all products goin back in are a step up from the stock build ~ Goin with Darkhorse crankworks crank, gonna bore to 113 and do the cp pistons/rings ~ Whole bottom will be new except the cases. Just will be going nuts with the wait...
Looks like your paying to have the work done, why not go bigger than 113, the cost won't be much different.
What are you going to do with the old parts? I'm sure you're not going that far and put the 259s back in.
Goin with the Woods 777's ~ I'll check on the 259e's ~ thinkin there may have been some metal in the bottom end ~ I'm going with a darkhorse crankworks crank/flywheel (SE trued, welded, plugged and balanced for the 113" C&P Pistons. Feuling Camplate/Oil Pump/Zippers cam chain tensioners/ woods 777's, boring the jugs and a set of worked heads ~ should be a good solid motor puttin out 120+Hp and 125+TQ ~ I just want a solid platform to go with the Baker DD7 ~ I'll let ya know on the cams...
I could go bigger but in my small brain ~ the bigger I go the more stuff I can break ~ my goal is 100k motor (2-2.5 years for me) ~ Just want a nice mix of power & dependability ~ This thinking may be wrong but I would be happy if I am at 120+hp and 125+tq ~ So you are probaly right dbel ~ but I'm already headed down the path and hope to do some ridin with ya in South FL ~ SemperFi
Good luck MitchD, just went thru this 12 months ago with rod bearing in lower end. I agree build one that you can get the other 80k miles on. Looking forward to seeing how it all turns out.
Still waiting ~ The crank seems to be the holdup ~ all parts except for crank ~ all machine work in the cases, heads, & jugs are complete ~ just a few days to assemble, and all will be well. List includes:
Darkhorse Crank w Carillo Rods ~ Welded, proplugged, trued
Timken Bearing Conversion
Zippers Cam Chain Tensioners
Woods Cams (not sure which one yet)
Woods Directional Lifters
SE adj push rods
Hi Flo heads (Rosa's Cycles)
113 C&P Pistons/Rings
58mm Throttle body/intake
Only stock items will be cases and bored jugs ~
The bottom end should be rock solid/overbuilt for a touring application
The numbers should be 120+hp/130+tq ~ based on the dyno's at the woods website.
I am hoping another two weeks and I'll be ridin so I'll keep ya posted
Fortunately HD esp has a rental in the garage (10 days) and friends have been kind enuf to keep me on bikes since this little episode began.
BTW if you have not ridden a vrod it is definitely an interesting powerplant. I have a muscle in the garage till Friday. It starts pulling at 5k all the way to 9k ~ thinkin this would not help with my speeding tickets. I'm not sure if it would be right for a bagger yet but with a bit more torque would probably be a blast....
SemperFi
I had a 2009 Muscle. You're right, it's an all you can eat buffet on the top end of the Revolution engine. I always thought it was a little soft on the bottom end for anything bigger than a V-Rod. Now if you made that 1250cc into a 1753cc you might have something for a touring bike.
Good luck on getting your skunk back together soon.
Discussion Starter #17
Thanks on the wishes ~ The Skunk should be worth the wait ~ interested to see if HD tries the Revolution in the 15 Road Glide ~ Tried to by Brad Pitt's Road Rod (VRod Road Glide) on ebay but the seller and I were about 1200 bucks apart ~ Oh well ~ here I sit patiently awaiting a Revived Stronger Skunk ~
Discussion Starter #18
So the 12 CVO RG Custom is now a 113 Oasis Cycles Build
Rosa's Cycles reworked 110 Heads
Stock cylinders bored to 113
Screamin Eagle ADJ Pushrods
Woods TW8-6 Cams
Timken Conversion
Hefty Lefty on the Right Side
SilverMoon Crank with H Beam Rods
Wiseco 10 1/2 to 1 Pistons/Rings
S&S Power Tune Duals Jet Black
Technoresearch Fuel Management (also fixed DD7 Cruise Issue only working in 7th gear now works in 4th - 7th):)
HPI 58mm Throttle Body
My goal was to have a dependable touring platform.
Will let ya know dyno results after break in.
Initial impression is motor is quiet and responsive compared to the stage III that was done before I purchased ~ dyno'd at 104/109 with the Stage III.
Crank bad at 15,600 miles ~ (Rod bearing on the front cylinder), so might as well upgrade a couple of items.
I did not want to bore cases so 113 was the best option for me.
Bike is in breakin period and I have done 660 miles so far ~ it runs great ~ and definitely has a bit more snap. I have been diligent to keep the r's around 3k on the high end but can't wait to get the final dyno done.
I have to be cautious what I post here ~ I am not endorsing or recommending a specific shop ~ as there are many pro's out there and as many snakeoil salesman..... I am only providing my experience with the businesses I have done business with and am not discrediting any other organization. This disclaimer is on here since a few of my post's have mysteriously disappeared into cyberspace while the thread remains...
SemperFi
I know you are "chafing at the bit to let that horse out of the gate", but I know that you will break it in properly as this isn't your first rodeo, and you wern't selling peanuts at the last one...
Why did you go to the S&S exhaust?
Gotta put in 'dem disclaimers.
Discussion Starter #20
The S&S Exhaust was not my choice ~ I told em to do whatever they wanted ~ but I will say the black exhaust on my skunk looks great & the pipes sound great ~ SemperFi
1 - 20 of 25 Posts
