1 - 4 of 4 Posts
Just did a 117ci stage 3 kit on my 19 CVO RG (mako). Using jackpot 2/1/2 head pipe 4" magnaflow mufflers and PV tuner from Fuel Moto stage 3 map. Just asking if anyone did this on the 18 or 19 cvo 117ci and if they did a dyno? if so what were your overall numbers. was curious to see what i might be at before i do a dyno run.
thanks:grin:
Not the same but for compare sake, my Stage 2 117 on my '18 CVO has stock header pipe and Reinfart 4s with the SE Tuner and Power Cam and I am at 107HP and 127FPT with a lovely pull sheet and power through out the entire spectrum
What Cam are you going with for your S3 as well as other components outside of what you listed?
went with straight out the box stage 3 kit 498 HD cam it stays a 117ci motor just goes to 11:1 compression with cylinders and pistons.thx
Fuel moto shows a dyno chart of a stock 2018 117ci 94 HP 110 Torque. his stock tune gets it to 95 HP and 111 torque. his numbers with a full exhaust and tune is 104 and 123. i am hoping to be at 115-120hp and 130-135 torqu with stage 3 setup.
1 - 4 of 4 Posts
