Bike is sold! Finally. Thanks for all the interest. Went to a RG die hard who was run over on his last one. Time for a 2015 RG for me, yeah!
Well, I have decided to upgrade so here goes. 1998 Road Glide Ultra. $9,000.00 O.B.O. Slightly broken in Road Glide has 107687 miles on the frame but the entire drivetrain is new. The paint is still in pretty good shape but it has scratches on back of front fender and small dent in top of front fender. Saddle bags have a few scratches as well as the side covers and the tank has no large scratches in visible areas. You can see from pictures that it does not show it's age. I put an Ultima 120" motor and Revtech 6 speed transmission in the bike when it had 102979 miles on odometer so there are less than 5000 miles on drivetrain. I put a Mikuni HSR48 carburator and a Hypercharger on the motor for better mileage. Has a Pertronix 2 into 1 stainless steel black exhaust system with adjustable baffle via a flapper valve on it. It has an Alpine CDE-HD149BT stereo with SiriusXM, HD Radio, CD, and Bluetooth and a Soundstream 320 watt amplifier thru Polk Audio 6.5" front speakers and Polk Audio 5" rear speakers with the King Tourpak installed on the bike. Has the Biketronics adapter so the handlebar controls also control the stereo functions. As pictured it has the Harley chopped tourpak with wing LED brake light installed on it. Has the module to upgrade the rear turn signals to brake lights and has a flasher tail light bulb. Has LED strips on the side of the King Tourpak. Has projector fog lights with upgraded bulbs. Has air horn instead of puny Harley stock horn so they can hear you if you have to let them know you are there. Has Michelin Commander 2 tires with less than 2000 miles on them. When I upgraded the motor and transmission I put in a high torque starter, a new set of high friction clutches, a new clutch basket with a reduced ratio starter gear to reduce breakage. Also installed a 3 phase charging system and a new nylon block for the primary chain tensioner. Have also installed a set of Sweeper pull back handlebars with longer cables and new grips and foot rests on crash bar. I am also including an 18" windshield. Also included is a King Tourpak with Polk Audio 5" speakers and a factory liner. You will have to take the chopped tourpak off the quick disconnect rack or get another quick disconnect rack for the King tourpak, I only have one. It would cost you at least $2000.00 to add these to a regular Road Glide. All wiring is there to plug and play for each setup. The only change would be if you decided to go without a tourpak you would need to add an antenna mount. **Antenna on rack of King Tourpak and the Airhawk seat cushions ARE NOT INCLUDED in this deal! Buyer arranges own transport. NO WARRANTY and mileage will be slightly higher. If questions, just ask. Nick (980)522-1401 [email protected]
Discussion Starter · #7 ·
No, I never tried to find any touch-up paint because the bike had almost 108,000 miles on it. And it didn't have any major chips or scratches other than back of front fender and I was planning on doing a complete new paint set. If you need some help with paint codes, I can check with my sister-in-law, she works for Keystone, they provide most body shops across the nation. If you need some help on audio, let me know and I will help with what I can. I loved my set-up with that Alpine and Polk. Thanks. Nick
Discussion Starter · #8 ·
BIKE IS SOLD!!! Thanks for your interest. Went to a die-hard RG fan who was run over on his last one. Time for a 2015 FLTRXS in superior blue and adding a king tour-pak with speaker pods and smoke LED brake/tail/turn lights. YEAH!
